Le prix tout petit s envole quand on a rajouté 2 alimentations 5 volts correctes,un cable rj 45 plaqué argent et un câble optique .
Mais le clignotement des petites les vertes fait tout oublier.
Ethernet Optical Fiber Converter (Pair)
These devices are delivered in pairs and convert a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit noise, while enjoying the advantages of 1000Base-SX/LX optical fibre, i. e. the greatest possible transmission distance. The fiber optic port supports multimode SX and single mode LX transmission standards for distances up to several kilometers.
The implementation is simple. Simply connect your network source (router, switch...) to the RJ45 connector of the first converter via a twisted pair Ethernet cable and then connect the two converters together with optical fiber. Finally, simply connect the second converter to your destination device (computer) in RJ45. LED indicators indicate the operating status of the device.
Power adapter 5VDC 2A via Jack DC 5.5/2.5mm sold separately.
| Specifications | |
| Product type | Ethernet to Optical fiber converter |
| Chipset | QCA8334-AL3C |
| Input | 1x Ethernet RJ45 10/100/1000Base-T |
| Output | 1x Optical SC 1000Base-SX/LX |
| Compatible Ethernet cable category | Cat5e / Cat6 |
| Duplex modes | Full Duplex or Half-Duplex |
| General | |
| Supply voltage | 5VDC |
| Dimensions | 94 x 71 x 27mm |
| Case material | Metal |
| Color | Gray |
| Length (m) | N/A |
| Shielding | NC |
| Section (mm²) | N/A |
| Connector | RJ45 |
| Connector | Optical |
| Conductors material (Cable) | Optical Fiber |
| Conductors Plating (Cable) | None |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JACQUES M.
