SC / SC 1m
This fiber optic cable allows network data to be transmitted using light signals. This makes it possible to achieve much higher transmission rates than with a conventional RJ45 Ethernet cable with copper conductors. This cable can therefore be used to connect an Internet box with a FTTH fibre source or a switch with an optical fibre connector.
Product type | Optical fiber cable |
Length | 1m |
Connectors type | SC |
Propagation mode | Mono Mode |
Conductor section | 9/125µm |
Cable diameter | 2.8mm |
Sheath | PVC (LSOH standard) |
Attenuation | 0.38/0.24 dB/km |
Général | |
Color | Sheath : Yellow Connectors : Blue |
Length (m) | 1.0 |
Shielding | No |
Section (mm²) | N/A |
Connector | Optical |
Conductors material (Cable) | Optical Fiber |
Conductors Plating (Cable) | None |
