FURUTECH FI-28 (G) IEC Connector Pur Copper Gold Plated 24k Ø17.5mm
The Furutech FI-28 (G) is a very high performance IEC female connector, ideal for building an audiophile power cable without compromise. In addition to its gold-plated copper contacts, the FI-F28 also benefits from the proprietary Furutech Alpha anti-magnetic treatment.
4.8 / 5
By buying this product you get 33 loyalty points
Reference : 8915
119,00 €tax incl.
99,17 € tax excl.
Furutech FI-28 (G)
Furutech FI-28 (G) Connecteur IEC Cuivre Pur Plaqué Or 24k Ø17.5mm
The Furutech FI-28 (G) is a very high performance IEC female connector, ideal for building an audiophile power cable without compromise. In addition to its gold-plated copper contacts, the FI-F28 also benefits from the proprietary Furutech Alpha α anti-magnetic treatment, which involves two steps:
  1. Cryogenization of metals at -250°C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
  2. Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose force of attraction is constantly controlled so as not to leave any magnetic residue at the end of the treatment.
The FI-28 model also uses the patented Floating Field Damper System technology, which almost completely eliminates the creation of micro-zones of magnetic and electrostatic turbulence inside the connector, caused by the passage of current in the vicinity of certain sensitive components (metal fixing screws, cable clamping elements, etc.). These "floating" micro-fields of force conflict with the much stronger primary magnetic flux generated by the passage of current through the cable and connectors, inducing a form of electrical resistance that is harmful to conductivity, as well as being able to generate a form of distortion. Furutech manages to control these phenomena by connecting all the metal parts concerned to each other by means of a conductor which is responsible for bringing all these undesirable energies to earth.
The body of the connector is made of a composite material of Nylon and Fiberglass, offering extreme resistance to shocks, electric arcs and high temperatures.
The conductors are fastened by means of 3 colour-coded screws (2 poles + earth). The firmness of the fixing, obtained thanks to the Furutech Wire Clamp technology, eliminates any risk of accidental tearing or damage to the cable, while significantly improving the contact surface.
The connector is compatible with cables between 6 and 17.5mm diameter.
Product typeIEC C15 connector
Contacts materialPure Copper
Contacts platingGold 24k
TreatmentAnti-magnetism Alpha α
TechnologiesFloating Field Damper System
Wire Clamp (cable clamping technology. 17% improvement in contact surface area)
Body materialNylon and fiberglass
Connection typeTo screw
Min/Max cable diameterØ6.6mm - Ø17.5mm
Total dimensions76.2 x Ø39.6mm
Rated Voltage/Current250V/10A
125V 15A
Max cable diameter (mm)17.5
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)15.0
Rated current (A)10.0
6 reviews
Top Marque
toujours Top qualité avec Furutech, pas besoin d'aller chercher ailleurs
This review has been posted for FURUTECH FI-28 (G) IEC Connector Pur Copper Gold Plated 24k Ø17.5mm
Top Marque
toujours Top qualité avec Furutech, pas besoin d'aller chercher ailleurs...
Nuance de romance avec iec fI28 OR
Bonjour , iec fi28 g sur mon oyaide tunami V2 ,schuko FI 46 ncf , apres un rodage de 100 h , la fi 28 a une belle finesse du haut ,une petite chaleur agreable, une belle transparence , une bonne dynamique , je dirai tres equilibré avec un nuance de romance du a l or : ( fi46 ncf or ,fi38 or ,fi 28 iec or ,chalin or sont mes connecteurs preferes) je la recommande a mon avis a ce prix il y a pas mieux
Excellent
Enormément de détails et de finesse. Beaucoup de silence. Cette prise à beaucoup amélioré mes Nordost Heimdall 2
Prise IEC Furutech
Parfaite à part le serrage du câble avec des mâchoires peu adaptées.
The Furutech FI-28 (G) is a very high performance IEC female connector, ideal for building an audiophile power cable without compromise. In...
