SCHURTER Male IEC C14 Connector pour for Power Supply Extension Ø8.5mm
This IEC C14 cable-mount connector is ideal for creating a power extension for a device for designing a finished cable. Mounting the conductors of your cable on this connector is quick and easy using screw terminals.
Reference : 14108
10,90 €tax incl.
9,08 € tax excl.
Schurter IEC C14
Male IEC C14 Connector pour for Power Supply Extension Ø8.5mmConnecteur IEC C14 Mâle pour Rallonge d'Alimentation Ø8.5mm
This IEC C14 cable-mount connector is ideal for creating a power extension for a device for designing a finished cable. Mounting the conductors of your cable on this connector is quick and easy using screw terminals. It can withstand voltages of 250V AC and currents of up to 10A.
Product typeIEC Connector
IEC TypeC14
Max cable diameterØ8.5mm
Connection typeTo screw
Conforme RoHS
Max cable diameter (mm)8.5
Mounting typeTo screw
ConnecticMale
ConnectorIEC C14
Rated current (A)10.0
Excellent connecteur
Ce connecteur est un excellent produit. La qualité de celui-ci ne mérite aucune critique aussi bien à l'extérieur qu'à l'intérieur. La connexion des câbles est super facile et très efficace même avec des câbles de section moyenne. Super achat.
This review has been posted for SCHURTER Male IEC C14 Connector pour for Power Supply Extension Ø8.5mm
This IEC C14 cable-mount connector is ideal for creating a power extension for a device for designing a finished cable. Mounting the conductors of...
