VIBORG LF505G IEC C15 Angled Connector
This Viborg LF505G right-angle IEC C15 connector is ideal for designing and upgrading high-performance, high-quality power cables.
Reference : 22011
34,90 €tax incl.
29,08 € tax excl.
Viborg LF505G Right-Angle IEC C15 Connector Pure Copper OFC Copper / Silver / Gold Plated Ø19mm
VIBORG LF505G
This Viborg LF505G right-angle IEC C15 connector is ideal for designing and upgrading high-performance, high-quality power cables. Its pure copper contacts with OFC copper / silver / gold plating ensure very high conductivity and excellent resistance to oxidation. The insulation is made of nylon and fiberglass, robust and lightweight materials that are also electromagnetically neutral. Assembly is made very simple thanks to a screw-type mounting system.
Dimensions VIBORG LF505G
Technical specifications
Product typeRight-angle IEC C15 power connector
Contact materialPure copper
Contact platingOFC Copper / Silver / Gold
InsulationNylon and fiberglass
MountingScrew-on
Accepted cable diameterØ7-Ø19mm
Max conductor diameter / cross-sectionØ4.8mm / 6AWG 16mm²
Dimensions60 x 57.7 x 42.4mm
Packaging1x VIBORG LF505G
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticMale
ConnectorIEC C15
Contacts Plating (Connector)Copper
Rated current (A)15.0
VIBORG LF505G IEC C15 Angled Connector Pure Copper OFC Copper / Silver / Gold Plated Ø19mm
