Connecteur monté sur un câble Oyaide tunami v2, pas facile à installer car cable relativement rigide. Les vis de fixation sont moins qualitatives que sur les schuko VE512R
Power Connector IEC C13 Silver/Rhodium Plated Copper Ø20mm
The IEC C13 Viborg VF502R power connector is a high end model. It offers a very nice design quality with pure copper contacts and a triple plating with OFC copper, silver and rhodium ensuring a very good conductivity and resistance to oxidation. The body of the connector is made of a particularly robust aluminum alloy. The connector accepts cables up to 20mm in diameter and conductors up to 4.5mm in diameter. Mounting is simple using a screw system.
Product type | IEC C13 power connector |
Contacts material | Pure copper |
Contacts plating | OFC Copper Silver Rhodium |
Min/Max cable diameter | Ø6mm - Ø20mm |
Max conductors diameter | Ø8mm |
Mounting | To screw |
Rated voltage/current | 125V 15A 250V 10A |
Total dimensions | Ø40*81.5mm |
Body dimensions | Ø40*63.7mm |
Color | Silver |
Max cable diameter (mm) | 20.0 |
Mounting type | To screw |
Connectic | Female |
Connector | IEC C13 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
Contacts Plating (Connector) | Rhodium |
Rated current (A) | 16.0 |
Average votes 4.8 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
pascal v.
bernard g.
Paul G.
Philippe S.
