MENNEKES SCHU-MC230/16PSW Power Connector Schuko Ø13mm
This robust and durable Mennekes Schuko connector (type E/F) allows you to design high-quality power cables at a low cost. Compatible with cables up to 13mm in diameter, it ensures easy installation thanks to its screw-on system, with no soldering required.
Reference : 21713
11,91 €tax incl.
9,92 € tax excl.
Shipping date: 01-12-2026.
Mennekes SCHU-MC230/16PSW Power Connector Schuko Type E/F 16A Plastic Ø13mm
Photo of a Mennekes E/F Schuko power connector
Product typeMale Schuko connector
Country of manufactureGermany
Body materialPlastic
GroundingYes
Mounting typeScrew-on
Voltage / Current230V 16A
Max. cable diameter13mm
Max. conductor section2.5mm²
Dimensions113x42mm
Weight66g
PackageSold individually
Max cable diameter (mm)13.0
Mounting typeTo screw
ConnecticMale
ConnectorSchuko
Contacts Plating (Connector)Nickel
Rated current (A)16.0
MENNEKES SCHU-MC230/16PSW Power Connector Schuko Type E/F 16A Plastic Ø13mm
This robust and durable Mennekes Schuko connector (type E/F) allows you to design high-quality power cables at a low cost. Compatible with cables...
