VIBORG VE501G Schuko Type E/F Power Connector Silver / Gold Plated 24K Pure Copper Ø19mm
This Viborg VE501G Schuko connector is ideal for designing and upgrading high performance and high quality power cables. Its pure copper contacts with gold plating ensure a very high conductivity and resistance to oxidation.
Reference : 15819
62,00 €tax incl.
51,67 € tax excl.
Shipping date: 22-10-2026.
Viborg VE501G
Power Connector Schuko Silver / Gold Plated 24K Pure Copper Ø19mm Black
Viborg VE501G Connecteur Secteur Schuko Cuivre Pur Plaqué Or Ø19mm Noir
This Viborg VE501G Schuko connector is ideal for designing and upgrading high performance and high quality power cables. Its pure copper contacts with silver / gold plating ensure a very high conductivity and resistance to oxidation. The insulation is made of nylon and fiberglass, strong, light and electromagnetically neutral materials. The assembly is very simple thanks to a screwing system.
Product typeSchuko connector
Contacts materialPure copper
Contacts platingSilver / Gold
InsulationNylon and glass fiber
Mounting typeTo screw
Acceptable cable diameterØ6-19mm
Max conductor diameter / sectionØ4mm / 12.5mm²
Voltage / Current250VAC 16A
DimensionsHeaight: 64mm
Diameter : Ø33mm
Length : 83.6mm
Max cable diameter (mm)19.0
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
6 reviews
fiche schuko viborg
Excellente fiche de très bonne qualité et très bien conçue.
This review has been posted for VIBORG VE501G Schuko Type E/F Power Connector Silver / Gold Plated 24K Pure Copper Ø19mm
Le top
J'en utilise depuis quelques années et je n'ai ai vraiment aucune envie d'en changer. J'ai eu du furutech fp-s032n fp-tcs31 oyaide Vondita avec ces Viborg c parfait... d'ailleurs il y a des marchands sur le net qui vendent des câbles à 300 400€ avec ce schuko. Encore une pépite Audiophonics
AV
I will write one review for all ordered goods.
I appreciate a very good approach to the customer in an effort to help in every situation. Very good communication, responses to questions come almost immediately. Thumbs up. I believe that such an approach is standard.
Goods: I ordered the brand of goods on recommendation. I think it's OK.
Grande Qualité
Connecteur qualitatif, solide, facile à monter avec très bon maintien du câble.
NOTE importante de montage: la rondelle en plastique de l'embase peut s'enlever le temps du montage pour libérer la rondelle de caoutchouc de centrage du câble, pour qu'elle ne soit pas abimée quand on manipule le câble dans l'embase, lors de sa fixation.
RQP IMBATTABLE
Je fais la même analyse que le commentaire précédent.
Cette gamme 501 pur cuivre plaquée or/ argent fonctionne à merveille.
Associez les prises shuko et IEC à l’excellent câble secteur Elecaudio CS361B et vous obtiendrez un résultat incroyable.
Après 30 heures environ de mise sous tension (rodage) cet ensemble révélera tout son potentiel.
Des basses percutantes, un aigüe fin et détaillé sans agressivité. Mais le top c’est le registre des médiums. Je n’ai jamais entendu autant de présence et de définition
Bref, c’est une vraie bombe et pour un coup dérisoire.
Essayez c’est l’adopter.
Je revends tous mes câbles à 4 chiffres si ça vous intéresse ?
This Viborg VE501G Schuko connector is ideal for designing and upgrading high performance and high quality power cables. Its pure copper contacts...
