This Viborg VE501S Schuko connector is ideal for designing and upgrading high-performance, high-quality power cables. Its pure copper contacts with OFC copper / silver plating ensure very high conductivity and excellent resistance to oxidation. The insulation is made of nylon and fiberglass, robust and lightweight materials that are also electromagnetically neutral. Assembly is very simple thanks to a screw-lock system.
Technical Specifications
| Specifications | |
| Product type | Schuko Connector |
| Contact material | Pure Copper |
| Contact plating | OFC Copper / Silver |
| Insulation | Nylon and fiberglass |
| Assembly | Screw-lock |
| Compatible cable diameter | Ø6-19mm |
| Maximum conductor diameter / cross-section | Ø4.5mm / 19mm² |
| Voltage / Current | 250VAC 16A |
| Dimensions | Height: 64mm Diameter: Ø33mm Length: 83.6mm |
| Color | Black |
| General | |
| Packaging | 1x VIBORG VE501S Schuko Power Plug |
| Max cable diameter (mm) | 4.5 |
| Mounting type | To screw |
| Connectic | Male |
| Connector | Schuko |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Silver |
| Contacts Plating (Connector) | Copper |
| Rated current (A) | 16.0 |
