SUCA AUDIO DA-2120C Class D FDA Amplifier TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Black
This small Suca Audio DA-2120C amplifier is a powerful FDA, based on a TAS5352A amplifier chip capable of developing a comfortable power of 2x90W under 4Ω, and this with a high efficiency, inherent to the Class D architecture.
Reference : 15362
189,00 €tax incl.
157,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by another model, the FOSI AUDIO DA-2120C Amplifier FDA Class D TAS5352A.
Suca Audio DA-2120C
Suca Audio DA-2120C Amplificateur FDA Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Noir
This small Suca Audio DA-2120C amplifier is a powerful FDA, based on a TAS5352A amplifier chip capable of developing a comfortable power of 2x90W under 4Ω, and this with a high efficiency, inherent to the Class D architecture. Versatile, it takes advantage of a complete connectivity with a panel of inputs capable of meeting most needs. We can find Coaxial, Optical, USB-B, RCA but also Bluetooth 5.0, offering the possibility to broadcast your music from a distance, from a smartphone for example. On the output side, the DA-2120C offers of course speaker terminals, but also a subwoofer output, for the integration of a 2.1 system.
All the components are integrated in a beautiful and robust CNC machined aluminum case. This one is equipped with an LED screen on the front and can be controlled with the remote control provided.
Product typeAmplifier
Amplifier typeFDA (Class D)
Output power2x90W @ 4Ω (1% THD / 32V)  / 2x120W @ 4 Ohm (10% THD / 32V)
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x Stereo RCA
Bluetooth 5.0
OutputsSpeaker terminals
1x Subwoofer output (RCA)
Bluetooth 5.0 codecsAAC, SBC, aptX, aptX LL
Max speaker impedance4-8Ω
Supported sampling ratesPCM up to 24bit 192kHz
Input sensitivity0.775V
Frequency response20Hz - 20kHz (±1dB)
SNR≥ 105dB
THD0.001%
Power supply24-36VDC (32V power supply included)
Dimensions183 x 128.5 x 37mm
Housing materialAluminum
Package1x DA-2120C Black
1x Remote (AAA batteries not included)
1x 32V Power Supply
1x Bluetooth antenna
1x Optical cable
1x USB-A to USB-B cable
Excellente découverte !
J'ai découvert par hasard ce modèle SUCA AUDIO DA-2120C, avec une puce d'amplification que je ne connaissais pas, donc j'ai décidé de le tester, en face de mon Alientek D8.
Et bien le constat est là, plus puissant, plus précis, et meilleure tenue des graves. Il possède le Bluetooth en direct, que n'a pas l'Alientek D8 (obligé de rajouter un récepteur bluetooth externe). Je l'ai testé en Bluetooth et Optique, en mode HiFi (sans tone).
J'étais très content de mon petit Alientek à moins de 120€, et ce FDA va encore un peu plus loin, pour une poignée d'euros de plus.
Je recommande grandement !
 (5)
This review has been posted for SUCA AUDIO DA-2120C Class D FDA Amplifier TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Black
This small Suca Audio DA-2120C amplifier is a powerful FDA, based on a TAS5352A amplifier chip capable of developing a comfortable power of 2x90W...
