This HIFI 2000 GX148 all-aluminium case will allow you to create and dress your DIY creations. Strong, it will prove to be durable and will perfectly protect all the components of your device.
Aluminum Housing 104 x 280 x 40 Front face 10 mm Argent
This HIFI 2000 housing Galaxy GX148 entirely aluminum is a great solution for your DIY projects.
Elegant and long-lasting, it provides excellent protection for your device electronic components. It has air holes on its top cover to allow the air to circulate and dissipate the heat. The GALAXY serie by HIFI 2000 counts small and medium-sized housings which are ideal for active filters, preamplifiers...etc.
| Specifications | |||
| Dimensions | Height | Length | Width |
| Internal | 40 | 104 | 280 |
| External | 42 | 124 | 291 |
| Parts | |
| Type | Self-Assembly Housing |
| Front face | Aluminum 10mm thick |
| Back face | Aluminum 3mm thick |
| Side covers | Aluminum extruded 10mm thick |
| Top & bottom covers | Steel 2mm |
| Weight | 1Kg |
