DAYTON AUDIO ME820C Coaxial Ceiling Speaker (Pair)
The Dayton Audio ME820C is a ceiling speaker designed for installation in any location and is ideal for use as a surround sound system or as left and right channels for a home cinema setup. Its design combines a 20.3cm (8") woven Kevlar cone woofer with a 2.54cm (1") silk dome tweeter mounted on a swivel bracket that allows the tweeter to be directed towards the listening position, ensuring rich sound reproduction even at high volumes.
By buying this product you get 22 loyalty points
Reference : 21892
226,90 €tax incl.
189,08 € tax excl.
Dayton Audio ME820C Coaxial Ceiling Speaker 45W 88dB 30Hz-20kHz 20.3cm (Pair)
xxx
Their integrated metal grille and understated design, combined with their robust acoustic construction, make these speakers ideal for installations requiring consistent performance.
Technical characteristics
Product typeCeiling speaker
Speakers1x Woofer Kevlar Ø20.3cm (8")
1x Tweeter Silk Ø2.54cm (1")
Power handlingRMS: 45W
Max: 90W
Impedance8Ω
Sensitivity89dB @ 1W/1m (+/-3dB)
Frequency response30Hz-20kHz
Grill materialMetal
Outer diameter (with grill)Ø27.94cm (11")
Mounting depthØ9.84cm (3-7/8")
Total depthØ10.8cm (4-1/4")
Cutout diameterØ25.4cm (10")
Weight6.03kg
PackageVendu par paire
Speaker Power (W RMS)45.0
Speaker TypeCeiling Speaker
Impedance (Ω)8
Loudspeaker diameter (mm)203.0
Diaphragm typeSilk
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)30
Highest frequency (Hz)20000
DAYTON AUDIO ME820C Coaxial Ceiling Speaker 45W 88dB 30Hz-20kHz 20.3cm (Pair)
The Dayton Audio ME820C is a ceiling speaker designed for installation in any location and is ideal for use as a surround sound system or as left...
