article bien reçu, bien emballé et qualité est exceptionnelle, j'ai testé le haut parleur est incroyable le son est parfait surtout les basses.
Speaker Driver Subwoofer DVC Glass Fiber 300W 2 ohm 84dB 30Hz-800Hz Ø20.3cm
Dayton Audio's Ultimax series of dual-coil subwoofers use the latest in subwoofer technology. As a result, the UM8-22 Ultimax is capable of delivering extremely deep and punchy bass. Its 2Ω dual voice coil allows for 2Ω stereo and 1Ω mono wiring configurations when paired with high current car or professional audio amplifiers to extract maximum power. For home applications, simply wire the coils in series for a 4Ω load and better compatibility with HiFi amplifiers.
To improve power handling, thermal management and power compression, Dayton Audio has designed the Ultimax range with large anodized frames and aerated pole pieces, under spider ventilation and double layer copper coils. It also benefits from a large travel capacity with a linear displacement, thanks to the use of a double spider, which also limits distortion. The rubber surrounds with integrated seals maintain the speaker surface in case of extreme deflection. The thick Nomex diaphragm has a woven glass fiber coating, creating an ultra rigid, distortion resistant surface.
A large copper tube and copper end cap in the motor reduce energy storage from the inductor, thereby reducing distortion for faster response. Large, high-energy magnets give this subwoofer a Qts such that it can be used in both open and closed speaker cabinets.
| Specifications | |
| Speaker driver type | Subwoofer |
| Nominal diameter | Ø20.3cm (8") |
| Power handling | RMS : 300W Max : 600W |
| Impedance | 2+2Ω |
| Frequency response | 30Hz - 800Hz |
| Sensitivity | 84.2dB @ 2.83V/1m |
| Voice coil diameter | Ø50.8mm (2") |
| Weight | 5.19kg |
| Thiele-Small Parameters | |
| Resonant frequency (Fs) | 31.6Hz |
| DC Resistance (Re) | 4.2Ω |
| Voice coil inductance (Le) | 1.14mH |
| Mechanical Q (Qms) | 2.51 |
| Electromagnetic Q (Qes) | 0.75 |
| Total Q (Qts) | 0.58 |
| Compliance equivalent volume (Vas) | 21.3L (0.75ft.³) |
| Mechanical compliance of suspension (Cms) | 0.33mm/N |
| Force factor (BL) | 9.1Tm |
| Diaphragm mass inc. airload (Mms) | 74.5g |
| Max linear excursion (Xmax) | 16mm |
| Surface area of cone (Sd) | 211.2cm² |
| Materials | |
| Cone material | Nomex Glass fiber |
| Surround material | Rubber |
| Voice coil wire material | Copper |
| Voice coil former | Aluminum |
| Basket / Frame material | Cast aluminum |
| Magnets material | Ferrite |
| Mounting informations | |
| Overall outside diameter | Ø210mm |
| Cutout diameter | Ø189mm |
| Depth | 143.5mm |
| Number of mounting holes | 8 |
| Optmum cabinet size (measured with BassBox 6 Pro) | |
| Sealed volume | 9.9L (0.35t³) |
| Sealed F3 | 49Hz |
| Vetend volume | 21.2L (0.75t³) |
| Vetend F3 | 30Hz |
| Speaker Power (W RMS) | 300.0 |
| Speaker Type | Subwoofer |
| Impedance (Ω) | 2+2 |
| Loudspeaker diameter (mm) | 203.0 |
| Diaphragm type | Glass fiber |
| Efficiency / Sensitivity (dB) | 84.0 |
| Max Linear Excursion (Xmax) (mm) | 16.0 |
| Lowest frequency (Hz) | 30 |
| Highest frequency (Hz) | 800 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JIOVANNI A.
