Audio Extractor HDMI 5.1 to HDMI / Optical / Jack HDCP2.2 HDR 4K 60Hz ARC
This extractor / splitter can support 4 HDMI input signals. Video output is 4K 60hz compatible with HDR and Dolby Vision support. The HDMI audio output allows DTS-HD, Dolby True HD and other signals to be passthrough.
This allows, among other things, to separate the stream to be able to play 4K HDR movies with HD sound on a home cinema amplifier that does not manage 4k HDR.
Reference : 15496
94,90 €tax incl.
79,08 € tax excl.
Shipping date: 28-05-2026.
Extracteur HDMI
Extracteur Audio HDMI 5.1 vers HDMI / Optique / Jack 3.5mm HDCP2.2 HDR 4K 60Hz ARC
This extractor / splitter can support 4 HDMI input signals. It then makes it possible to separate the video stream from the audio stream, keeping the encodings. Video output is 4K 60hz compatible with HDR and Dolby Vision support. The HDMI audio output allows DTS-HD, Dolby True HD and other signals to be passthrough.
TV ARC signal is supported for output to optical or headphone port only.
The HDMI audio stream can also be routed to the optical (5.1 max) or headphone port.
It also complies with the HDCP 2.2 standard. Finally, a remote control allows it to be controlled from a distance.
Beware though, it does not support CEC.
Product typeHDMI extractor / switch
Inputs4x HDMI
Outputs1x HDMI (ARC compatible)
1x HDMI (audio only)
1x Optical Toslink
1x Jack 3.5mm headphone output
Supported video resolutions4K @ 60Hz
4K @ 30Hz
1080p
720p
480p
ARC function
HDMI Audio formatsDTS-HD, Dolby TrueHD, LPCM 7.1, DTS, Dolby AC3, DSD Color
Bit depth (video)8/10/12bit @ 1080p
8bit @ 2160p
Audio output formatsLPCM 2.0
DTS
Dolby AC3
Maximum usable cable length (@ 26AWG, HDMI 2.0)2160p : < 5m
1080p : < 10m
Supported audio sampling ratesPCM up to 24bit 192kHz
HDMI Transmission bandwidth25~600MHz
HDMI Transmission speed0.75~18Gbps
Supply voltage5VDC 1A
Operating temperature range0°C ~ +40°C
Dimensions205 x 74 x 26mm
Weight350g
Package1x HDMI switch
1x IR Remote control
InputHDMI
OutputJack 3.5mm
OutputOptical Toslink
OutputHDMI
Extracteur au top.
m'a permis de prolonger la vie de mon préampli Yamaha CX-A5000 qui ne supporte pas le 4k 60Hz HDR de mon Apple TV. J'ai maintenant une image au top sur ma TV Philips Oled et profite du son HC de mon ensemble.
merci à Audiophonics pour les conseils. Top.
This review has been posted for Audio Extractor HDMI 5.1 to HDMI / Optical / Jack HDCP2.2 HDR 4K 60Hz ARC
This extractor / splitter can support 4 HDMI input signals. Video output is 4K 60hz compatible with HDR and Dolby Vision support. The HDMI...
