HDMI to HDMI / Optical / Jack 3.5mm Extractor 5.1 18Gbps HDCP 2.2 4K 60Hz HDR ARC 3D CEC
This extractor allows you to recover and extract an HDMI signal at the input and then output both in HDMI, Optical Toslink and Jack 3.5mm to distribute the audio signal independently. The extractor is compatible with 4K, HDR, 3D, ARC, CEC with a bandwidth of 18Gbps.
Reference : 17045
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 01-05-2025.
HDMI Extractor
HDMI to HDMI / Optical / Jack 3.5mm 5.1 18Gbps HDCP 2.2 4K 60Hz HDR ARC 3D CEC
Extracteur HDMI vers HDMI / Optique / Jack 3.5mm 5.1 18Gbps HDCP 2.2 4K 60Hz HDR ARC 3D CEC
This extractor allows you to recover and extract an HDMI signal at the input and then output both in HDMI, Optical Toslink and Jack 3.5mm to distribute the audio signal independently. The extractor is compatible with 4K, HDR, 3D, ARC, CEC with a bandwidth of 18Gbps. A selector allows you to choose the number of channels, for a stereo, 5.1 or pass-through operation. In the same way, a switch allows to activate or not the ARC function.
If you use the HDMI and optical outputs simultaneously, make sure you use cables with compact connectors. The HDMI and optical outputs of the extractor are indeed close to each other.
1ARC ON/OFF switch
2Pass-Through / 2.0 / 5.1 selector
3HDMI input LED
4HDMI input
55VDC power input via Micro USB
6Jack 3.5mm headphone output
7Optical Toslink output
8HDMI output
Product typeHDMI extractor
Input1x HDMI
Outputs1x HDMI
1x Optical Toslink
1x Jack 3.5mm
Supported resolutions4K 60Hz, 2K, 1080p, 720p...
Supported technologiesHDR
CEC
ARC
3D
Max bandwidth18Gbps
Package1x HDMI extractor
1x USB-A to Micro USB cable
InputHDMI
OutputOptical Toslink
OutputHDMI
OutputJack 3.5mm
This extractor allows you to recover and extract an HDMI signal at the input and then output both in HDMI, Optical Toslink and Jack 3.5mm to...
