REAL CABLE HD2A113-4K Audio HDMI Extractor to SPDIF / Jack 3.5mm DTS Dolby HD HDCP2.2 4K 60Hz HDR
This compact HDMI audio extractor extracts the signal from a wired HDMI connection and distributes it as a digital audio signal under the Toslink or Coaxial outputs. There is also a 3.5mm jack analog output.
Reference : 17581
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 24-06-2025.
Audio HDMI to HDMI ARC and Optical Extractor - 4K 3D CEC
HDMI audio extraction & HDMI video signal passage : The extractor can provide the audio signal from an HDMI connection of one of your devices (console, Blu-ray player, etc.) via these two optical outputs (toslink or coaxial) or via its 3.5mm Jack output allowing you to connect your sound system. In addition, the video signal passes through the HDMI output retranscribing up to 4K 60i / s.
This HDMI extractor is ideal for a home cinema setup.
REAL CABLE HD2A113-4K Extracteur audio HDMI vers SPDIF / Jack 3.5mm DTS Dolby HD HDCP2.2 4K 60Hz HDR
Product typeHDMI Extractor
InputsHDMI (type A)
Outputs1x HDMI (type A)
1x optical Toslink
1x optical coaxial
1x Jack 3.5mm (analog)
HDMI compatibility and video formats supportedHDMI 2.0
HDCP1.4 et 2.2
UHD 4K 60i/s
HDR
HDTV 4K and Pixel Clock Rate until 600MHz
Audio formats supportedStereo mode 2.0 : PCM 2.0 (stereo)
Multicanals mode 5.1 : Dolby digital 5.1 / DTS 5.1
Compatible with Dolby true HD lossless and DTS HD Master Audio
Contacts platingGold
Power supplyDC 5V 1A
Dimensions120 x 60 x 30 mm
Weight80g
Package1x Extracteur HDMI REAL CABLE HD2A113-4K
InputHDMI
OutputJack 3.5mm
OutputHDMI
OutputOptical Toslink
OutputCoaxial SPDIF
This compact HDMI audio extractor extracts the signal from a wired HDMI connection and distributes it as a digital audio signal under the Toslink...
