This eARC HDMI switch/splitter offers extensive connectivity and exceptional flexibility to suit all multimedia configurations. It supports a wide range of HDMI sources, such as game consoles, computers, TVs and projectors. It can connect up to four HDMI sources to a single display or projector, and operates in bidirectional mode with up to 7.1 channels of eARC technology. In addition to HDMI inputs and outputs, this device is equipped with a 3.5mm headphone output, a Toslink optical output and a coaxial output for easy connection to a Hi-Fi system. Dedicated control buttons allow you to manage the various functions, including an EDID DIP switch for manual EDID (Extended Display Identification Data) configuration and resolution of display or sound problems.
The top DIP switch corresponds to position 0, while the bottom DIP switch corresponds to position 1. The 4th DIP switch selects the device operating mode: 0 for the switch and 1 for the splitter.
DIP Switch EDID settings | |||
1 | 2 | 3 | Functions |
0 | 0 | 0 | Copy EDID from HDMI output |
0 | 0 | 1 | Upgrade mode |
0 | 1 | 0 | 4K/60Hz 5.1 channels |
1 | 0 | 0 | 4K/60Hz 7.1 channels |
1 | 1 | 0 | 1080P/60Hz 2 channels |
1 | 4x HDMI in / eARC out |
2 | 1x HDMI out / eARC in |
3 | DC 5V power supply |
4 | EDID DIP switch |
5 | Jack 3.5mm headphone output |
6 | Optical Toslink output |
7 | Coaxial output |
8 | IR receiver |
9 | "TV Audio" button |
10 | eARC button |
11 | Input switch |
Product type | HDMI 4x1 switch / eARC 1x4 splitter |
HDMI resolution | 4K/60Hz |
Inputs | 5 HDMI ports (HDMI 4x1 / eARC 1x4) |
Outputs | 5 HDMI ports (HDMI 4x1 / eARC 1x4) Jack 3.5mm headphone output Optical Toslink output Coaxial output |
Weight | 245g |
Dimensions | 122 x 117 x 19mm |
Package | 1x HDMI 4x1 Switch / eARC 1x4 Splitter 1x IR remote control 1x DC 5V power supply |
Input | HDMI eARC |
Input | HDMI |
Output | HDMI eARC |
Output | Jack 3.5mm |
Output | HDMI |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Max sampling rate | NC |
Color | Black |
Interface chip | NC |
