DAN CLARK VIVO Balanced Headphone Cable 4.4mm Jack to 2x Hirose 2m
The DAN CLARK VIVO is a high-end balanced headphone cable developed by Dan Clark Audio, designed to replace the original cable of compatible headphones and provide a connection to a 4.4mm balanced Jack output.
By buying this product you get 36 loyalty points
Reference : 22455
364,90 €tax incl.
304,08 € tax excl.
Dan Clark VIVO Balanced Headphone Cable 4.4mm Jack to 2x Hirose Silver-Plated OFHC Copper 2m
DAN CLARK VIVO
The Dan Clark VIVO is a high-end balanced headphone cable developed by Dan Clark Audio, designed to replace the original cable of compatible headphones and provide a connection to a 4.4mm balanced Jack output. It uses silver-plated OFHC copper conductors and features a geometry specifically designed to combine transmission quality, high flexibility, and excellent ergonomics. Fully customized by Dan Clark Audio and inspired by VOCE cables, the VIVO stands out for its ultra-lightweight and non-microphonic design, as well as for its sound described as smooth and spacious. It is equipped with a 4.4mm balanced Jack connector on the source side and two Hirose connectors on the headphone side, providing a solution suitable for Dan Clark Audio headphones compatible with this connection.
Technical specifications
Product typeBalanced headphone cable
Connectors1x 4.4mm Jack
2x Hirose connectors
Conductor materialsSilver-plated OFHC copper
Headphone compatibilityAEON, NOIRE, ETHER, E3
Length2m
Packaging1x Dan Clark VIVO Balanced Headphone Cable 4.4mm Jack to 2x Hirose
Length (m)2.0
ShieldingNC
Section (mm²)N/A
ConnectorHirose
ConnectorJack 4.4mm
DAN CLARK VIVO Balanced Headphone Cable 4.4mm Jack to 2x Hirose Silver Plated OFHC Copper 2m
The DAN CLARK VIVO is a high-end balanced headphone cable developed by Dan Clark Audio, designed to replace the original cable of compatible...
