DDHIFI M198C Earphones Cable USB-C to MMCX DAC CS43198 1.2m
The ddHiFi M198C is a USB-C to MMCX cable which, in addition to offering signal transmission via an OCC 5N copper conductor, includes a Cirrus Logic CS43198 chip for analogue-to-digital conversion up to PCM 32bit 384kHz and DSD256.
Reference : 21131
99,90 €tax incl.
83,25 € tax excl.
ddHiFi M198C Earphones Cable USB-C to MMCX OCC Copper DAC CS43198 1.2m
DD HiFi M198C : Front view
ddHiFi M198C: CS43198 DAC
The M198C cable is equipped with a Cirrus Logic CS43198 chip supporting file conversion up to PCM 32bit 384kHz and native DSD256, allowing you to enjoy lossless tracks without compromise.
DD HiFi M198C : USB-C connector
DD HiFi M198C : USB-C splitter and connector
ddHiFi M198C: OCC copper cable
To ensure optimal data transmission, DD HiFi's M198C cable uses a conductor made of OCC N5 copper strands, offering optimal conductivity. In addition, this cable uses aluminium connectors, combining a sleek and classy aesthetic with unbeatable durability. Finally, this cable also includes a microphone nestled in the heart of the splitter, allowing you to make calls with ease.
ddHiFi M198C: LED
For greater clarity, the USB-C connector features a discreet LED whose colour changes depending on the DAC chip's operation. A blue light indicates standby mode, a green light indicates PCM decoding, and a red light indicates DSD decoding.
DD HiFi M198C : Blue LED
Product typeHeadphone cable with DAC
Connectors1x USB-C
2x MMCX
Length1.2m
Conductive materialOCC Copper
DAC ChipCS43198
Native DSD up to DSD256
Dynamic range≥ 125dB
Total harmonic distortion more noise (THD+N)< 0.0003% @ 32Ω
Signal-to-noise ratio (SNR)≥ 125dB
Output power2x80mW @ 32Ω
2x38mW @ 16Ω
ColorSilver
PackageSold by unit
Length (m)1.2
ShieldingNo
Section (mm²)N/A
ConnectorMMCX
ConnectorUSB-C
DDHIFI M198C Earphones Cable USB-C to MMCX OCC Copper DAC CS43198 1.2m
The ddHiFi M198C is a USB-C to MMCX cable which, in addition to offering signal transmission via an OCC 5N copper conductor, includes a Cirrus...
