DDHIFI BC130C ERYX RHP Earphones Cable
The ddHiFi BC130C Eryx earphones cable features a high-end design using audiophile-grade materials. It is fitted with a rhodium-plated copper 4.4mm balanced jack and a proprietary ddHiFi interchangeable connector system, allowing the user to choose between an MMCX or 0.78mm CIEM connection. The conductors in this cable are a hybrid blend of German OCC and OFC copper, pure silver and gold-plated OCC, for optimal signal transmission and improved signal clarity.
By buying this product you get 59 loyalty points
Reference : 21968
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 12-11-2026.
ddHiFi BC130C Eryx RHP Earphones Cable 4.4mm Balanced Jack to Interchangeable Connectors MMCX / CIEM 0.78mm OCC Copper Plated Rhodium
Miniature of the ddHiFi BC130C Eryx RHP
Furthermore, this cable features two layers of internal insulation for effective protection against interference and to reduce noise levels. This is complemented by a rosewood reinforcement combined with a titanium alloy, which absorbs micro-vibrations and reduces distortion to deliver the purest and most precise sound across the entire frequency range.
ddHiFi BC130C Eryx: An audiophile design
The ddHiFi BC130C Eryx cable features four 25AWG conductors, each made from a hybrid blend of German OFC copper, OCC copper, gold-plated OCC copper and high-purity silver. These characteristics ensure optimal signal transmission. Furthermore, each conductor is individually insulated to preserve the transmission of different frequencies. The cable features PVC insulation with double black braided mesh shielding.
Image showing a cross-section of the BC130C Eryx cable
Image showing the various interchangeable connectors on the BC130C Eryx
ddHiFi BC130C Eryx: Interchangeable and reliable connectors
The RHP version of the ddHiFi BC130C Eryx features, as its name suggests, a balanced 4.4mm jack with rhodium-plated OFC copper contacts, as well as interchangeable connectors allowing you to choose between MMCX and 0.78mm CIEM. This cable is therefore compatible with the majority of IEMs available on the market. In addition, two versions of 0.78mm CIEM connectors are included:
  • a transparent body for the long version
  • a black body for the flat version
Product typeEarphones/IEM cable
Connectors1x 4.4mm balanced rhodium-plated jack connector
3x interchangeable connectors (1x MMCX + 2x 0.78mm in-ear monitors)
Section4x 25AWG (4x 0.162mm²)
Conductive materialOCC Copper, German OFC Copper, Gold-plated OCC Copper, Pure Silver
InsulationDouble SoftPlex PVC (USA) braided in black mesh
AccessoryRosewood combined with titanium alloy components
Weight28g
Length1.2m
Packaging1x ddHiFi BC130C Eryx RHP headphone cable
1x Pair of MMCX connectors
2x Pair of 0.78mm in-ear connectors
1x Storage box
Length (m)1.2
ShieldingNo
Section (mm²)0.16
ConnectorCIEM 0.78mm
ConnectorJack 4.4mm
ConnectorMMCX
Conductors material (Cable)Silver
Conductors Plating (Cable)Gold
DDHIFI BC130C ERYX RHP Earphones Cable 4.4mm Balanced Jack to Interchangeable Connectors MMCX / CIEM 0.78mm
The ddHiFi BC130C Eryx earphones cable features a high-end design using audiophile-grade materials. It is fitted with a rhodium-plated copper 4.4mm...
