MOONDROP SILVERPILL Earphones Cable 4.4mm Jack to 0.78mm CIEM 1.2m
The Moondrop Silver Pill is a high-end audiophile replacement cable designed for in-ear monitors (IEMs). It features a multi-layer braided coaxial design and uses high-purity silver-plated OFC copper conductors treated with an oil-immersion process to optimize audio signal transmission.
By buying this product you get 56 loyalty points
Reference : 21543
569,00 €tax incl.
474,17 € tax excl.
Moondrop Silverpill Earphones Cable 4.4mm Jack to CIEM 0.78mm Silver-Plated OFC Copper Dual Shielding 1.2m
Photo of the MOONDROP SILVERPILL
The Moondrop Silver Pill is a high-end audiophile replacement cable designed for in-ear monitors (IEMs). It features a multi-layer braided coaxial design and uses high-purity silver-plated OFC copper conductors treated with an oil-immersion process to optimize audio signal transmission. Its dual-layer shielding structure reduces loss and interference, while stainless steel metal components ensure strength and durability. Equipped with 0.78mm 2-pin connectors and a balanced 4.4mm termination, the Silver Pill is engineered to enhance sound performance and reliability for compatible audiophile IEMs.
Moondrop Silverpill: Silver-plated OFC Hybrid Conductors with Oil Immersion
The Silver Pill uses high-purity silver-plated oxygen-free copper conductors treated through an oil immersion process. This treatment improves signal stability and optimizes electrical performance.
Technical benefits:
  • High conductivity and stable transmission
  • Rich, clean, and detailed sound reproduction
  • Improved clarity and resolution
  • Reduced signal loss
This hybrid architecture is designed to maximize the acoustic performance of connected IEMs.
MOONDROP SILVERPILL: Silver-Plated OFC Hybrid Conductors with Oil Immersion
MOONDROP SILVERPILL: Triple-layer braided coaxial structure & dual copper shielding
Moondrop Silverpill: Triple-Layer Braided Coaxial Structure & Dual Copper Shielding
The cable features a professional two-strand architecture with a triple-layer coaxial structure:
  • 48 pure copper strands (Ø 0.05mm each)
  • 0.6mm insulation layer
  • 13×7-core pure copper shielding
  • Dual copper shielding for the main core
This design reduces electromagnetic interference and transmission loss while improving signal consistency and precision.
Moondrop Silverpill: High-Precision Connectors & 316 Stainless Steel Components
The metallic elements (connectors, splitter, and jack shell) are made from 316 stainless steel, known for its mechanical strength and durability.
The cable also features:
  • A high-precision gold-plated OFC copper 4.4mm balanced plug
  • 0.78mm 2-pin IEM connectors
  • A premium metal finish ensuring protection and longevity
MOONDROP SILVERPILL: High-Precision Connectors & 316 Stainless Steel Components
Technical Specifications
Product typeIEM cable
Conductor materialSilver-plated OFC copper
StructureTriple-layer braided coaxial
Shielding
ConnectorsCIEM 0.78mm
Termination4.4mm jack
Length1.2m
Package contents1× Moondrop Silverpill
Length (m)1.2
ShieldingYes
Section (mm²)0.18
ConnectorCIEM 0.78mm
MOONDROP SILVERPILL Earphones Cable 4.4mm Jack to 0.78mm CIEM Silver Plated OFC Copper Double Shielding 1.2m
The Moondrop Silver Pill is a high-end audiophile replacement cable designed for in-ear monitors...
