ZIIGAAT Z-01 Earphones Cable 1.2m
The ZiiGaat Z-01 is a high-end cable designed for in-ear monitors (IEMs), featuring a 5N single-crystal copper construction. This cable stands out for its LITZ Type 1 construction, which minimizes signal loss and reduces impedance to just 0.4592 Ω, resulting in natural, detailed, and balanced sound reproduction.
Reference : 21689
29,91 €tax incl.
24,92 € tax excl.
Shipping date: 01-12-2026.
ZiiGaat Z-01 Earphones Cable CIEM 0.78mm to Jack 3.5mm Copper Gold Plated 1.2m
ZiiGaat Z-01
ZiiGaat Z-01: A high-quality cable
The ZiiGaat Z-01 uses 5N single-crystal copper conductors, renowned for their purity and ability to transmit audio signals efficiently. The LITZ Type 1 construction reduces interference and signal loss, ensuring a clearer and more immersive listening experience. This combination of materials and design makes it an ideal accessory for discerning audiophiles.
ZiiGaat Z-01: Connectors
The Z-01 cable features a standard 3.5mm jack on one end and is compatible with a wide range of in-ear headphones thanks to its 0.78mm 2-pin CIEM connectors on the other end. This versatility allows it to be used with many models of Hi-Fi earphones, offering an easy and effective upgrade for users looking to enhance their listening experience.
Product typeEarphones cable
Earphones connectorsCIEM 0.78mm 2 pins
Source connectorJack 3.5mm
Cable conductors material5N Copper (Litz Type 1)
Cable conductors structure4 conductors
32 cores * 0.08mm per conductor
Connectors contacts platingGold
Outer sheath materialPVC
Length1.23m ±2cm
Impedance0.4592Ω
ColorBrown
Length (m)1.2
ShieldingNo
Section (mm²)N/A
ConnectorCIEM 0.78mm
ConnectorJack 3.5mm
ZIIGAAT Z-01 Earphones Cable CIEM 0.78mm to Jack 3.5mm Copper Gold Plated 1.2m
The ZiiGaat Z-01 is a high-end cable designed for in-ear monitors (IEMs), featuring a 5N single-crystal copper construction. This cable stands out...
