TANCHJIM Earphones Cable CIEM 0.78 2 Pins to Jack 3.5mm 1.2m
This earphones cable from Tanchjim is designed to replace a damaged cable or upgrade a standard cable. It features 5N OCC copper conductors, ensuring excellent conductivity for perfect signal transmission. In addition, the contacts on its connectors are gold-plated to maintain excellent conductivity while protecting them from oxidation. This version is equipped with two 0.78mm 2-pin CIEM connectors on one end and an single-ended 3.5mm jack connector on the other.
Reference : 21045
59,90 €tax incl.
49,92 € tax excl.
Tanchjim Earphones Cable CIEM 0.78 2 Pins to Jack 3.5mm 5N OCC Copper 1.2m
Tanchjim CIEM 3.5mm jack earphone cable
Product typeEarphones cable
Connectors2x CIEM 0.78mm 2 Pins
1x Jack 3.5mm
Cable conductors material5N OCC copper
Length1.2m
Length (m)1.2
ShieldingNC
Section (mm²)N/A
ConnectorCIEM 0.78mm
ConnectorJack 4.4mm
TANCHJIM Earphones Cable CIEM 0.78 2 Pins to Jack 3.5mm 5N OCC Copper 1.2m
This earphones cable from Tanchjim is designed to replace a damaged cable or upgrade a standard cable. It features 5N OCC copper conductors,...
