This earphones cable from Tanchjim is designed to replace a damaged cable or upgrade a standard cable. It features 5N OCC copper conductors, ensuring excellent conductivity for perfect signal transmission. In addition, the contacts on its connectors are gold-plated to maintain excellent conductivity while protecting them from oxidation. This version is equipped with two 0.78mm 2-pin CIEM connectors on one end and an single-ended 4.4mm jack connector on the other.
| Specifications | |
| Product type | Earphones cable |
| Connectors | 2x CIEM 0.78mm 2 Pins 1x Jack 4.4mm |
| Cable conductors material | 5N OCC copper |
| Length | 1.2m |
| General | |
| Color | Black |
| Length (m) | 1.2 |
| Shielding | NC |
| Section (mm²) | N/A |
| Connector | Jack 4.4mm |
| Connector | CIEM 0.78mm |
| Conductors Plating (Cable) | None |
