MOONDROP MIS-TIP T55-L IEM Ear Tips Large (Pair)
The Moondrop MIS-Tip T55 are memory foam ear tips designed to optimise the interface between the IEM and the ear canal, relying on a 5.5mm inner diameter to ensure stable mechanical compatibility with IEM nozzles ranging from 6 to 7mm. This dimensional match allows uniform retention without excessive stress, while promoting a gradual insertion that improves acoustic seal and positional stability.
Reference : 22137
9,00 €tax incl.
7,50 € tax excl.
Shipping date: 17-11-2026.
Moondrop MIS-TIP T55-L Foam IEM Ear Tips Ø5.5mm Large (Pair)
MOONDROP MIS-TIP T41-S : Front view
MOONDROP MIS-TIP T41-S : Frequency response curve
Designed for multi-driver earphones, they utilise the expansive properties of the foam to ensure uniform acoustic coupling despite more complex internal designs, thereby minimising pressure losses and perceived phase variations.
Technical caracteristics
Product typeIEM ear tips
Inner diameterØ5.5mm
MaterialMemory foam
Compatible IEM nozzle diameterØ6-7mm
PackageSold as a pair
MOONDROP MIS-TIP T55-L In-Ear Monitors Eartips Foam Ø5.5mm Large (Pair)
The Moondrop MIS-Tip T55 are memory foam ear tips designed to optimise the interface between the IEM and the ear canal, relying on a 5.5mm inner...
