DOUK AUDIO VU56PRO RGB LED VU Meter Mic+Line
The DOUK Audio VU56PRO is an RGB LED VU meter with 8 display effects, operating effectively on the 20Hz-20KHz frequency band. The signal input is via stereo RCA or 3.5mm Aux jack, but it is also possible to use the VU56PRO's built-in microphone so that the signal does not pass through the device.
Reference : 21120
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 28-05-2026.
Douk Audio VU56PRO RGB LED VU Meter Mic + Line
DOUK AUDIO VU56PRO
The Douk Audio VU56PRO is an RGB LED VU meter with 8 display effects, operating effectively on the 20Hz-20KHz frequency band. The signal input is via stereo RCA or 3.5mm AUX jack, but it is also possible to use the VU56PRO's built-in microphone so that the signal does not pass through the device. However, if you decide to pass the signal through it, it has an RCA or 3.5mm Aux jack output. The VU56PRO is powered by 5V 1A via micro-USB and comes with a remote control for remote operation.
DOUK Audio VU56PRO overview
1RCA output
2RCA input
33.5mm Aux jack output
43.5mm AUX Jack Input
5Power / Display Effect Selector
6Line / Microphone input selection
7Built-in microphone
85V micro USB power supply
Product typeVumeter
Inputs1x Stereo RCA
1x 3.5mm AUX Jack
Outputs1x Stereo RCA
1x 3.5mm AUX Jack
Max input level2.5Vrms
Max. effective input level1.8 Vrms (the VU56 PRO will always display full power when this value is exceeded)
Monitoring frequency range20Hz-20kHz
Input impedance10KΩ
Brightness adjustment4 level
Display colorGreen or red
Display effects8 effects
Display length gain3 levels adjustable (-3 dB, 0 dB, +3 dB)
Display modePPM mode (peak programme meter) / VU Mode (volume unit)
Holding time of peak LEDAdjustable
Drop speed of main bar/peak LEDAdjustable
Remote control
Power suplyDC 5V (≥1A) via micro USB
Dimensions154 x 116 x 47mm
Weight400g
Package1x Douk Audio VU56PRO
1x 3.5mm AUX jack cable
1x Remote control (requires CR2025 battery, not included)
1x USB-A to Micro USB power cable (AC adapter not included)
Très bien
Produit bien fini qui donne de la vie à mon système audio. il me rappelle les vumètres des platines cassettes. Livré dans un super emballage qui fait très pro. Raccordé à la sortie RCA de mon lecteur réseau il offre une bonne indication du niveau et le choix des différents modes avec la télécommande est un plus. il manque juste un bouton marche/arrêt en façade car il faut bien penser à l'arrêter avec la télécommande avant d'éteindre les appareils audio. C'est un détail car c'est un appareil de qualité à un prix correct qui n'apporte aucune amélioration du son mais qui donne une touche sympathique et fait "danser" la musique.
This review has been posted for DOUK AUDIO VU56PRO RGB LED VU Meter Mic + Line
The DOUK Audio VU56PRO is an RGB LED VU meter with 8 display effects, operating effectively on the 20Hz-20KHz frequency band. The signal input is...
