Pack ASCILAB C8C + ASCILAB BX8C Black
This AsciLab pack consists of a pair of C8C cardioid bookshelf speakers and a pair of BX8C subwoofers. Designed to work together, the BX8Cs connect in daisy chain with the C8Cs to provide extended bass and more powerful sound if you have a large space.
By buying this product you get 1186 loyalty points
Reference : 21397
11 869,00 €tax incl.
9 890,83 € tax excl.
Instead of 12 298,00 €
Pack content
Due to the nature of matte finishes, slight variations in gloss levels may occur depending on the production batch.
Pack AsciLab C8C + AsciLab BX8C Bookshelf Speakers Cardioid 3-way + Active Subwoofer Black (Pair)
AsciLab C8C + AsciLab BX8C : Front view
AsciLab C8C
The AsciLab C8C speakers are active 3-way cardioid speakers with a power output of 1x100W + 2x250W. They feature a central tweeter and two 6" ceramic woofers supported by two side subwoofers for powerful, immersive sound. Thanks to their unique design, they cover a very wide frequency range of 30Hz-20kHz while maintaining exemplary directivity and low distortion. In addition, their connectivity offers numerous configurations: a micro USB-B port provides access to a 9-band equaliser to fine-tune the settings of your C8C speakers according to their position in the room, the style of music being played or simply your preferences.
AsciLab C8C
AsciLab C8C
AsciLab BX8C
AsciLab BX8C
The AsciLab BX8C are active subwoofers featuring a total of four 20.32 cm (8") drivers and 2x250W amplification in a system with exceptional directivity. Designed to complement the C8C speakers by extending their bass response, the combination of the two offers remarkable neutrality in frequency response and impressive directivity, allowing for unaltered sound quality regardless of the environment.
AsciLab BX8C
AsciLab C8C Specifications
Product typeActive speakers
Number of channels3-way
DirectivityCardioid
Tweeter1x 1" alumina ceramic dome tweeter and waveguide
Woofer2x 6" alumina ceramic woofers
Subwoofer2x 8" active subwoofers
Crossover frequencies1.2kHz, 150Hz, 4th order
Amplification100W for high frequencies
250W for midrange frequencies
250W for low frequencies
Integrated DSP9 bands via Hypex controller software
Net weightApproximately 27.5 kg/speaker
Dimensions560 x 254 x 350mm
AsciLab BX8C Specifications
Product typeActive subwoofer
Power2x250W
Speakers4x Ø20.32cm loudspeaker
Speaker membraneAluminum
Crossover frequency100-300Hz
Bass extension"Max SPL" mode : 100Hz
"Standard Cardioid" mode : 50Hz
"Extended Cardioid" mode : 35Hz
Dimensions800 x 254 x 350mm
Pack ASCILAB C8C + ASCILAB BX8C Bookshelf Speakers Cardioid 3-way + Active Subwoofer Black (Pair)
This AsciLab pack consists of a pair of C8C cardioid bookshelf speakers and a pair of BX8C subwoofers. Designed to work together, the BX8Cs connect...
