COVID-19 Virus information. Find the latest regularly updated information about the status of our services.
PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + SMSL SA-36A PLUS Amplifier
PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + FX-AUDIO D302 PRO FDA Amplifier
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an SMSL SA-36A PLUS amplifier. It thus constitutes an almost complete audio system at a low price but still powerful. An ideal set to enjoy a quality reproduction, especially in a small / medium room.
Reference : 13996
140,83 €tax excl.
Instead of 149,09 €
Including 0,04 € for green tax
Pack content
  • 1 x
    In Stock
    The SMSL SA-36A Plus black is a remarkably efficient compact audio amplifier that takes advantage of a wide range of connectors allowing it to be associated with it from many different sources.
    49,92 € 49,92 €VAT
    In Stock
  • 1 x
    In Stock
    The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass boomer/midrange offering a good transient regime while ensuring low mechanical deformation.
    99,17 € 99,17 €VAT
    In Stock
Pack Davis Acoustics MIA 20 + SMSL SA-36A Plus
Speaker Bookshelf 2 Way + Amplifier 2x30W
Pack Enceintes Bibliothèques Davis Acoustics MIA 20 + SMSL SA-36A PLUS
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an SMSL SA-36A Plus Amplifier. It thus constitutes an almost complete audio system at a low price but still powerful. An ideal set to enjoy a quality reproduction, especially in a small / medium room.
Pack Enceintes Bibliothèques Davis Acoustics MIA 20 + Amplificateur FDA FX-Audio D302 Pro
Davis Acoustics MIA 20 Bookshelf Speaker
Smaller model from Davis Acoustics, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass driver/midrange driver offering good transient performance while ensuring low mechanical deformation, as well as a 25mm soft dome tweeter made of coated fabric. In addition, the speaker body contains a high quality crossover filter, providing linear listening for long hours of listening without listening fatigue while providing accurate playback. A Bass Reflex system with a large front vent allows you to deliver deep bass. The frontal positioning of these vents allows the MIA 20 to be placed directly against a wall. The 88dB efficiency of these speakers allows them to be associated with all amplifiers on the market.
At the rear, the speaker offers screw terminals that accept banana plugs, but also a system that allows the speakers to be simply positioned against a wall.
Test des Davis Acoustics MIA 20 par On-Mag
" Listening, the Davis Mia 20 are real HiFi speakers that have a lot of charm. For the price at which they are offered, there is not much to complain about. We know of many more expensive ones that sound much worse. "
The SMSL SA-36A Plus is a remarkably efficient, compact audio amplifier that takes advantage of a wide range of connectors allowing it to be associated with many different sources.
Indeed, this amplifier has a USB input, an SD card input, an AUX jack 3.5mm, and an Wireless Bluetooth 4.1 antenna.
Its amplifier module TPA3118 Class D allows it to deliver an output power of 2x30W under 8 Ohm. It benefits from high quality electronic components.
On its front panel, 5 buttons of commands. A Play / Pause button, the 2 volume buttons +/-, the Power button, as well as the button for the various buttons settings EQ Mode .
Qobuzissime for the SMSL SA-36A Plus
(Review by Qobuz)
" This S.M.S.S.L SA-36A Plus switching amplifier may have amazed us even more than the AD18 and A8 models of the brand..."
Test Qobuz
Davis Acoustics MIA 20 Specifications
Product typeSpeakers
Speaker formatBookshelf speaker
PowerNominal: 80W RMS
Max: 110W
Number of way2
Speaker driver number2
Efficiency88dB
Frequency response55Hz - 20kHz
Tweeter25mm, dôme souple
Medium / Woofer13cm, fiberglass
ImpedanceMin. 5Ω
Cutout frequency3000Hz
Bass ReflexFront laminar air vent
Binding post typeScrew binding posts, accept banana plugs
FinishBlack wood
SMSL SA-36A Plus
Amplifier chipTPA3118 / Class D
Power output 2x 30W into 8 Ohm
Bluetooth Version4.1
Maximum Sample Rate16 Bit / 44kHz
EQ modeFlat / Rock / Pop / Classic / Jazz
Power supply24V DC (included)
Power consumption22W
Idle power consumption0.5W
Supported file formatsWMA / MP3
InputsUSB-A (64GB max)
SD card (32GB max)
3.5mm jack (AUX)
OutputStereo speaker terminals
Dimensions250x188x68mm
Weight322G
Pack content1x Pair of Davis Acoustics MIA 20 speakers
InputSD Card
InputUSB-A
InputJack 3.5mm
InputUSB 2.0
OutputSpeaker terminal
Max sampling rate44.1kHz
Channel2 channels (Stereo)
amplifier chipTPA3118
Power (max)30W
Colissimo - TNT - SoColissimo
Le matériel chinois m’étonneras toujours
FX-AUDIO D302 PRO entièrement plug and play aucun drivers usb a installer même sous XP, déactive toute la couche audio du pc pas dommage.
la qualité du son est égale voir supérieur a mon ampli NAD C658 de 10kg , avec la puissance en moins , mais largement suffisante pour sonorisé un salon de 75m²
les enceintes Davis bonnes pour leurs dimensions, rendement pas terrible les basses manque de définition, pour ce prix il ne faut pas rêver non plus .
This review has been posted for PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + SMSL SA-36A PLUS Amplifier
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an SMSL SA-36A PLUS amplifier. It thus...
