By buying this product you get 115 loyalty points
The Quloos QA860 DAP reader is a gifted one. It is dreadfully effective for dematerialized reading. The DAC section with a 4-layer circuit and dual DAC AD1955 24 bit 192Khz ensures a seamless conversion and musicality rarely reached.
The preamplifier section with triple Op Amps LME49720 with digital variable volume allows to attack a power amplifier by Cinch RCA or true balanced outputs.
The DAC AD1955 dual voltage stage is designed with two OP Amp 2134 Burr Brown and a preamplifier section, three Op Amp LME 49720.
The dual-stage headphone output allows dual listening for both madam and sir. This is completely separated from the preamplifier stage with an Op Amp LM49720 followed by an OPA2134.
This stage arrives on the integrated amplifier TPA6162 for headphones even at high impedance (600 Ohm).
VIMA and Rodenstien MKP capacitors, LT1965 LDO controllers, there is nothing missing to guarantee a high-level Bit-Perfect digital audio without (jitter) jitter.
Managing the Quloos proprietary buffer that is transported in I2s ensures high-precision transfer of digital data.
The dual power circuits with a transformer for digital, one for the analog provide a great stability and a great recoil of the background noise.
The digital clock section on filt power supplyEMI RFI has two modules (22.57MHZ and 24.576MHZ) regulated TCXO with low drift, with an accuracy of 0.5PPM. The two transformers designed on specifications are on anti-vibration supports so as not to affect the two TCXO clocks.
The quality of the chassis finish of the QA860 is in line with its interior design, sober, superbly assembled. Of a formidable efficiency, the interface of reading is all simply the fastest of the readers DAP of the market. It takes less than a second after you load an SD card to listen to music in high-definition DSD.
DWith its technical choices, its competition DAC, the QA860 is a formidable file player dematerialized on SD cards. Bringing fidelity and simplicity of operation, it will entice the amateur wanting a computer solution free of any network problems.
Warning! The volume is inoperative in DSD playback. The output will be fixed and non-variable. The USB port is currently not functional and waiting for a future update.
Features:/ Strong>
Digital Outputs:
Digital Inputs:
Digital Outputs:
Analog Outputs:
Active ingredients used:
Comes with :
Supported file types:
The QA860 supports SD / SDHC / SDXC cards up to 128GB SDXC with FAT32 formatting.
electrical characteristics and dimensions:
