SABAJ A20A 2022 Amplifier Stereo Class D Infineon MA5332M Bluetooth 5.0 2x170W / 1x350W 4 Ohm
Sabaj's A20A 2022 is a powerful, high-performance Class D stereo amplifier. With its 2x170W under 4Ω, it will allow you to accompany even the most demanding speakers, while providing a particularly convincing sound reproduction, both accurate and rich. Moreover, it can operate in BTL mono mode to develop a power of 350W and will be able to drive a subwoofer completely thanks to a dedicated mode.
Reference : 17037
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 16-07-2025.
Sabaj A20A 2022
Class D Amplifier Infineon MA5332 Bluetooth 5.0 2x170W 4 Ohm BTL 1x350W
Sabaj A20A Amplificateur Class D Infineon MA5332 Bluetooth 5.0 2x170W 4 Ohm BTL 1x350W
Infineon MA5332M amplification chip
The Class D amplifier stage of the Sabaj A20A uses a high efficiency Infineon MA5332M chip, capable of developing a significant power of 2x170W under 4Ω or 350W in mono BTL. It also offers a sound restitution of a great precision and a beautiful dynamic, the whole with great fidelity.
BTL mode
The Sabaj A20A can be used in BTL mode. Thus, you can have a mono amplifier that can deliver a power of 350W, ideal to accompany demanding speakers.
Subwoofer mode
The A20A's built-in low-cut filter is activated when the subwoofer mode is on. This allows you to drive a subwoofer dynamically while taking advantage of the high power of the amplifier. The crossover frequency can be adjusted over the range of 70Hz to 200Hz to accommodate different subwoofers.
The use of this mode requires the joint use of the BTL mode.
Bluetooth 5.0
In addition to its RCA and XLR inputs, the Sabaj A20A is equipped with a Bluetooth 5.0 receiver, so it is possible to broadcast and control your music remotely, from a smartphone or a tablet for example.
xxx
1ON/OFF button
2Volume button
2Low pass cutofffrequency selection
4Input selector
5ON/OFF filter selector
6Stereo / BTL selector
7RCA analog input
8RCA / XLR input selector
9XLR analog input
10Bluetooth antenna connector
11Right channel speaker output
12Left channel speaker output
13Power connector
Product typeAmplifier
Amplification typeClass D
Amplification chipInfineon MA5332M
Number of channelStereo (2) or mono BTL (1)
Output power2*170W @ 4Ω
2*90W @ 8Ω
1*350 @ 4~8Ω (BTL)
Inputs1* Stereo RCA
1* XLR
OutputSpeaker terminals
THD+N0.004%
SNR103dB
Channels separation90dB
Low pass cutoff frequency range70~200Hz
Input sensitivity / impedance430mV / 22kΩ
Supply voltage100-240VAC
Dimensions (L*P*H)200*187*60mm
Weight1.8kg
Housing materialAluminum
ColorSilver and black
InputXLR
ColorSilver
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipInfineon MA5332M
Power (W)350.0
Power (W)170.0
4 reviews
Musical et costaud !
Mon ancien lecteur CD (Arcam CD37) tient très bien le grave; et le Sabaj aussi. Le reste du spectre sonore est aussi bien musicalement restitué par le A20A.
Il y a 15 ou 25 ans, un ampli. de cette qualité valait plusieurs milliers de fr., etait plus volumineux et lourd ...
L'essai de rendu en BT est aussi très bon.
L'espace 3D est bien présent, mais un peu "compacté"; j'avais un ampli. à tubes en classe A OTL qui était plus aéré en 3D, mais beaucoup plus onéreux.
Je ne peux pas essayer sa polyvalence de connections, mais cela complète les bénéfices de cet appareil.
Vu ses petites dimensions, il faut être soigneux avec les petits commutateurs arrières.
Bref, une acquisition, que personne ne regrettera.
En plus, son esthétique est plaisante.
This review has been posted for SABAJ A20A 2022 Amplifier Stereo Class D Infineon MA5332M Bluetooth 5.0 2x170W / 1x350W 4 Ohm
INCREDIBILE!
Amplificatore veramente potente e con un suono decisamente soilfisticato! Pilota anche i sassi! Se usato in mono è addirittura spaventoso! Qualità sonica HI END!
Tutto questo a casa per 200 euro... Incredibile ma vero!
J'avais pour projet la recherche d'un "petit" ampli mono afin de driver une Triangle Secret LCR7, enceinte encastrable pour en faire une enceinte centrale.
En effet étant mélomane et cinéphile, je me voyais mal passé d'un ampli stéréo à un ampli full home cinéma. Ayant en front une paire de JBL 4312 MK2 et en back des Klipsch RP 600 M, un caisson Klipsch R-115SW le tout relié à un Yamaha RN 803 D, il me manquait pour une meilleure lisibilitée des paroles dans les films une centrale.
Mon choix c'est porté après plusieurs jours de recherche sur la SABAJ A20 qui semblait répondre à mes exigences et je ne suis pas déçu ! Relié en rca Out,
Le son est surprenant de clarté et de puissance ! Vraiment très plaisant à l'écoute en plus du boîtier en alu assez classe, élément important.
Merci à Audiophonics pour les informations claires et détaillées, l'envoi super rapide ! Je recommande !
Excellent "petit" ampli.
Sabaj's A20A 2022 is a powerful, high-performance Class D stereo amplifier. With its 2x170W under 4Ω, it will allow you to accompany...
