AUDIOPHONICS LPSU100 Stabilized Power supply 19V 5.25A 100W NAS / Intel Nuc
4.9 / 5
Reference : 9644
290,00 €tax incl.
241,67 € tax excl.
Shipping date: 11-09-2026.
Linear Regulated Power LPSU100
19V 5.25A 100W NAS/Intel Nuc
The Audiophonics team is proud to present you this regulated linear power supply. It delivers clean power to your digital players, storage devices, and other sensistive audio equipment. It has a GX16 (aviation type) output format with a lockable inlet. The Power Supply delivers a voltage of 19V 5.25A.
Quality components are integrated in a rugged 100% Aluminum for increased robustness and reliability. This power supply is thus among the best value for money in this price range.
The GX16 cable to DC Jack 5.5 / 2.5mm required to use the power supply output is provided.
Positive is located in the center of the DC jack connector.
Type of productlinear regulated power supply
Input VoltageAC 220V
Tensions / output currents19V / 5.25A DC
Power100W
Output ConnectorsGX16 2 poles
GX16 cable to DC Jack 5.5 / 2.5mmprovided
Postif the center of the DC jack connector
Dimensions256x206x65 mm
Weight4.3kg
silver brushed aluminum facade
Parts supplied
Cable GX16 2 poles 1.5mX1
Power Cable Not Provided
InputIEC C14
OutputGX12
ColorSilver
Output voltage (V)19.0
Output current (A)6.25
Input voltage (V)230.0
Power SupplyLinear
18 reviews
Excellent
Acheté pour mon NUC Roon afin de tenter d'améliorer le résultat sonore : l'image s'est élargie, la dynamique s'améliore un peu, le grave est plus tendu le médium et l'aigu gagnent en présence en l'absence de toute dureté. Je suis donc pleinement satisfait de mon achat.
Je regrette toutefois que la diode rouge soit si violente et que l'option façade noire ne soit pas proposée (cela fait tache au milieu de mon système.)
Mais l'amélioration est là pour un prix qui reste assez raisonnable.
This review has been posted for AUDIOPHONICS LPSU100 Stabilized Power supply 19V 5.25A 100W NAS / Intel Nuc
Great product.
Belle alimentation
J ai acheter cette alimentation pour couper un boucle de masse et surtout pour alimenter correctement un mini PC dédié a l'audio.
Le résultat est la...plus de boucle de masse. Mon système est devenu parfaitement silencieux et les alimentation du pc rien avoir c est propre et silencieux.Le 5V des ports USB et maintenant bien régulé.
isolation galvanique et alim linéaire parfaitement régulee..c est la base du silence
Excellent
Fast delivery. Excellent device.
Suggestions:
1. offer a black faceplate as alternative
2. the psu is over dimensioned for a single intel nuc or intel-nuc-based-audio-device. Consider providing a second 19v output and second cable (as a bookshelf option?).
Very good quality and solidly built power supply
Packaging was very good (double boxed and good protection foam inside). The power supply is much bigger and heavier than I imagined, but that is good.
Solidly built, good solid connections and works perfectly with my NUC8.
