By buying this product you get 79 loyalty points
Ultra Low Noise Regulated Linear Power Supply 5 / 7V + 9 / 12V 4A
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful design with a high quality toroidal transformer and a separate ground for each rail. This internal design provides an ultra-low noise signal and cancels all "buzzing" at 50Hz and maximum load. The power supply also includes protection against exceeding the maximum operating temperature (Over Temperature Protection). All components are placed in a robust and stylish black brushed Aluminium case. The brand logo is stamped into the Aluminium on the power supply cover. A display on the front panel shows the voltage and current delivered by each output.
The Keces P8 is particularly interesting also because it offers two adjustable DC outputs. Thus, the first output can be set to 5V or 7V while the second output can be set to 9V or 12V. A switch on each output allows you to simply select the desired voltage. The P8 also has a USB connector delivering 5V. On the current side, each output is supplied with 4A. The input voltage is also selectable (230V or 115V AC) via a switch under the device, to adapt to the current supplied by your mains sockets.
| Specifications | |
| Product type | Regulated linear power supply |
| Input voltage (Switchable) | AC 110V-120V 60Hz AC 220V-240V 50Hz |
| Output voltage | Output 1 : DC 5V / 7V Output 2 : DC 9V / 12V |
| USB Output | 5V |
| Output connector | Jack DC 5.5/2.5mm |
| Consumption | 200W (full load) |
| Case | Brushed Aluminium 4mm |
| Dimensions | 300 x 220 x 66mm |
| Weight | 6kg |
| Color | Black |
| Package | 1x Keces P8 1x Power cable Schuko / IEC 2x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm cable 2x Jack DC 5.5/2.1mm to 5.5/2.5mm cable |
| Protections | ||||
| Output voltage | Over voltage protection | Under voltage protection | Overload protection | Over temperature protection |
| 5V | 5.5V | 4.5V | 4.2A | 80°C |
| 7V | 7.5V | 6.5V | 4.2A | 80°C |
| 9V | 9.5V | 8.5V | 4.2A | 80°C |
| 12V | 12.5V | 11.5V | 4.2A | 80°C |
| Input | IEC C14 |
| Output | Jack DC 5.5/2.5mm |
| Color | Black |
| Output voltage (V) | 7.0 |
| Output voltage (V) | 5.0 |
| Output voltage (V) | 9.0 |
| Output voltage (V) | 12.0 |
| Output current (A) | 4.0 |
| Input voltage (V) | 230.0 |
| Input voltage (V) | 120.0 |
| Power Supply | Linear |
