KECES P9 DUAL Ultra Low Noise Regulated Linear Power Supply
The Keces P9 is a low-noise regulated linear power supply, a direct successor to the P8, designed to provide stable, clean power to sensitive audio components. It delivers up to 5A per rail, with a peak capacity of 7A, utilising an in-house developed toroidal transformer, whose precise winding and carefully selected materials stabilise the voltage whilst limiting electrical interference upstream of the circuit power supply.
By buying this product you get 89 loyalty points
Reference : 21688
899,00 €tax incl.
749,17 € tax excl.
Keces P9 Dual Ultra Ultra Low Noise Regulated Linear Power Supply 5 / 7 / 9 / 12 + 12 / 15 / 19 / 24V 5A
Keces P9 : Front view
The Keces P9 Dual is a low-noise regulated linear power supply, a direct successor to the P8, designed to provide stable, clean power to sensitive audio components. It delivers up to 5A per rail, with a peak capacity of 7A, utilising an in-house developed toroidal transformer, whose precise winding and carefully selected materials stabilise the voltage whilst limiting electrical interference upstream of the circuit power supply.
This approach is further enhanced by a fully discrete circuit design, inspired by the P28, which prioritises precise and independent regulation of each stage, thereby maintaining a constant power supply without relying on integrated circuits. Building on this foundation, the ground isolation for each output separates the power rails, reducing interference between connected devices whilst ensuring a uniform power distribution.
The focus on noise reduction is also reflected in a design with very low ripple, maintaining a DC voltage free from unwanted components to ensure a clean and stable power supply. In line with this, the inclusion of gold-plated DC connectors minimises contact resistance, whilst the mains input module, wired with OCC silver and combined with a 2 oz copper PCB, optimises current flow and the handling of transient surges.
Designed for simultaneous power supply to multiple devices, it combines dual independent outputs, a dedicated earth terminal block and high current capacity, enabling the integration of a variety of configurations whilst managing electrical interactions. This design ensures silent operation, even at full load, with no 50Hz humming, whilst the built-in thermal protection monitors operating conditions to ensure long-term stability.
Product typeRegulated linear power supply
Outputs2x Jack DC
Output voltage1x 5 / 7 / 9 / 12V DC output
1x 12 / 15 / 19 / 24V DC output
Output current5A (Peak to 7A)
Ripple Noise220µV at full power
150µV at 60W
Maximum consumption330W
CasingAluminum
Dimensions300 x 220 x 66mm
Weight6kg
Conditionnement1x Keces P9 Dual
1x Mains cable
1x 5.5/2.5mm DC jack to 5.5/2.1mm DC jack cable
1x 5.5/2.1mm DC jack to 5.5/2.5mm DC jack adapter
KECES P9 DUAL Ultra Low Noise Regulated Linear Power Supply 5 / 7 / 9 / 12 + 12 / 15 / 19 / 24V 5A
The Keces P9 is a low-noise regulated linear power supply, a direct successor to the P8, designed to provide stable, clean power to sensitive audio...
