By buying this product you get 39 loyalty points
The LHY Audio LPS-50 PRO is a linear power supply designed to deliver a stable DC voltage to Hi-Fi devices, particularly DACs. It is based on the Linear Technology LT3041 regulator, arranged in a configuration of five outputs in parallel: this architecture reduces output impedance and internal resistance, while widening bandwidth and limiting residual ripple. The power supply thus delivers a low-noise voltage, suited to circuits sensitive to current variations and transients.
Measurements stated by the manufacturer indicate ripple below 20μV with no load and 100μV even under high-current operation. Its low dropout voltage improves efficiency compared to the previous generation and reduces heat generated by more than 60%, promoting stable long-term operation.
The design is based on a four-layer printed circuit board with immersion gold finish, in order to preserve electrical performance and signal integrity. The power stage combines Schottky diodes with high current capacity and low internal resistance, high-capacity Philips Vishay BC 058 electrolytic capacitors, X7R multilayer ceramic capacitors, as well as low thermal drift precision resistors and Panasonic capacitors. This selection aims to maintain voltage stability while handling fast current demands.
To control temperature, a pure aluminum conductive plate is attached beneath the printed circuit board. It aids heat evacuation and complements the improved efficiency of the regulator, contributing to stable dissipation during extended use.
The LPS-50 PRO features short-circuit, overload and overheating protections. These systems monitor operating conditions to limit risks to the power supply and the connected device in the event of a fault.
It is supplied with an Ultimate Series DC cable featuring high-purity oxygen-free copper conductors. Its 24K gold-plated aviation plug ensures a firm mechanical fit and a low-impedance connection, limiting losses between the power supply and the Hi-Fi equipment.
Technical specifications
| Specifications | |
| Product type | Linear Power Supply |
| Input | IEC14 |
| Outputs | 1x 2-pin aviation connector |
| Input voltage | 220V AC |
| Output voltage / current | 12V / 3.5A |
| Ripple noise | No load: <20μV Full load: <100µV |
| Enclosure material | Aluminum |
| General | |
| Dimensions | 130 x 60 x 250mm |
| Color | Black |
| Package | 1x LHY Audio LPS-50 PRO 1x Jack 5.5/2.1 cable |
| Input | IEC C14 |
| Output | Jack DC 5.5/2.1mm |
| Color | Black |
| Output voltage (V) | 12.0 |
| Output current (A) | 3.5 |
| Input voltage (V) | 230.0 |
| Power Supply | Regulated Linear Power Supply |
