LHY AUDIO LPS-50 PRO Low Noise Linear Power Supply 50W 5V 5A Jack 5.5/2.1mm
New
The LHY Audio LPS-50 PRO is a linear power supply designed to deliver a stable DC voltage to Hi-Fi devices, particularly DACs. It is based on the Linear Technology LT3041 regulator, arranged in a configuration of five outputs in parallel: this architecture reduces output impedance and internal resistance, while widening bandwidth and limiting residual ripple. The power supply thus delivers a low-noise voltage, suited to circuits sensitive to current variations and transients.
By buying this product you get 39 loyalty points
Reference : 22714
399,00 €tax incl.
332,50 € tax excl.
LHY Audio LPS-50 PRO Low Noise Linear Power Supply 50W 5V 5A Jack 5.5/2.1mm
LHY AUDIO LPS-50 PRO: Front view
Measurements stated by the manufacturer indicate ripple below 20μV with no load and 100μV even under high-current operation. Its low dropout voltage improves efficiency compared to the previous generation and reduces heat generated by more than 60%, promoting stable long-term operation.
LHY Audio LPS-50 PRO: Components and heat dissipation
The design is based on a four-layer printed circuit board with immersion gold finish, in order to preserve electrical performance and signal integrity. The power stage combines Schottky diodes with high current capacity and low internal resistance, high-capacity Philips Vishay BC 058 electrolytic capacitors, X7R multilayer ceramic capacitors, as well as low thermal drift precision resistors and Panasonic capacitors. This selection aims to maintain voltage stability while handling fast current demands.
To control temperature, a pure aluminum conductive plate is attached beneath the printed circuit board. It aids heat evacuation and complements the improved efficiency of the regulator, contributing to stable dissipation during extended use.
LHY Audio LPS-50 PRO: Protections and included DC cable
The LPS-50 PRO features short-circuit, overload and overheating protections. These systems monitor operating conditions to limit risks to the power supply and the connected device in the event of a fault.
It is supplied with an Ultimate Series DC cable featuring high-purity oxygen-free copper conductors. Its 24K gold-plated aviation plug ensures a firm mechanical fit and a low-impedance connection, limiting losses between the power supply and the Hi-Fi equipment.
Technical specifications
Product typeLinear Power Supply
InputIEC14
Outputs1x 2-pin aviation connector
Input voltage220V AC
Output voltage / current5V / 5A
Ripple noiseNo load: <20μV
Full load: <100µV
Enclosure materialAluminum
Dimensions130 x 60 x 250mm
Package1x LHY Audio LPS-50 PRO
1x Jack 5.5/2.1 cable
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)5.0
Output current (A)5.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
The LHY Audio LPS-50 PRO is a linear power supply designed to deliver a stable DC voltage to Hi-Fi devices, particularly DACs. It is based on the...
