LHY AUDIO SILENT DC Low Noise Power Supply 15V 5.6A
New
The LHY Audio Silent DC is a switching power supply designed to deliver stable DC current to compatible Hi-Fi audio devices. Its high-performance module combines a multi-stage CLC filtering matrix with an active noise cancellation system to reduce ripple and interference, with an output level in the microvolt (μV) range.
Reference : 22688
129,00 €tax incl.
107,50 € tax excl.
LHY Audio Silent DC Low Noise Power Supply 15V 5.6A
LHY AUDIO SILENT DC: Front view
Its all-aluminum alloy chassis promotes heat dissipation and helps maintain stable operation over time. Built-in short-circuit and overload protections safeguard both the power supply and the connected device.
Technical specifications
Product typeHiFi Power Supplies
InputIEC 14
Outputs1x GX16 2 pins
Input voltage100~240V AC, 50/60Hz
Output voltage / current15V 5.6A
Enclosure materialAluminum
Dimensions80 x 175 x 52mm
Weight560g
Package1x LHY Audio Silent DC
1x GX16 to DC Jack cable 1m
1x Power cable
InputIEC C14
OutputGX16
Output voltage (V)15.0
Output current (A)5.6
Input voltage (V)120.0
Input voltage (V)240.0
Power SupplySMPS
The LHY Audio Silent DC is a switching power supply designed to deliver stable DC current to compatible Hi-Fi audio devices. Its high-performance...
