The LHY Audio Silent DC is a switching power supply designed to deliver stable DC current to compatible Hi-Fi audio devices. Its high-performance module combines a multi-stage CLC filtering matrix with an active noise cancellation system to reduce ripple and interference, with an output level in the microvolt (μV) range.
Its all-aluminum alloy chassis promotes heat dissipation and helps maintain stable operation over time. Built-in short-circuit and overload protections safeguard both the power supply and the connected device.
Technical specifications
| Specifications | |
| Product type | HiFi Power Supplies |
| Input | IEC 14 |
| Outputs | 1x GX16 2 pins |
| Input voltage | 100~240V AC, 50/60Hz |
| Output voltage / current | 20V 4.2A |
| Enclosure material | Aluminum |
| General | |
| Dimensions | 80 x 175 x 52mm |
| Weight | 560g |
| Color | Black |
| Package | 1x LHY Audio SIlent DC 1x GX16 to DC Jack cable 1m 1x Power cable |
| Input | IEC C14 |
| Output | GX16 |
| Color | Black |
| Output voltage (V) | 20.0 |
| Output current (A) | 4.2 |
| Input voltage (V) | 120.0 |
| Input voltage (V) | 240.0 |
| Power Supply | SMPS |
