NATIV PULSE - Linear Regulated Power Supply for NATIV VITA and WAVE Walnut Stand
By buying this product you get 109 loyalty points
Reference : 12268
1 099,00 €tax incl.
915,83 € tax excl.
This is the Walnut version, with walnut base (dark wood)
NATIV PULSE Walnut
Regulated linear power supply for Nativ Vita and Wave
Nativ Pulse
Pure linear power.
Based on the principle that the sound quality depends greatly on the power supply of the system, Nativ offers the Pulse. This power supply features an ultra-sophisticated linear design, featuring customized components for analog and digital sections, low-noise linear regulators, a shielded toroidal transformer built on specifications and an AC line filter, all to get the most out of your audio system.
<!- RIGHT IMAGE / LEFT TEXT ->
The analog stage in the heart of the Pulse.
The Nativ Wave is composed of specific power supplies for each analog section and for digital circuits. The best controllers have been selected to protect the analog stages of para noisesite thus removing the jitter. With a capacity of more than 50000μF, this linear power supply will provide the power required for your system with great ease, allowing the system to go from total silence to amazing dynamics in an instant.
A custom transformer.
The Nativ Wave also incorporates a totally separate SMPS power supply that delivers stable current for non-audio components. This, extremely efficient, produces only a small noise below 50mVp-p at full load (5V).
Nuvotem Talema has designed exclusively for Nativ a toroidal transformer to measure, allowing to provide a clean and stable current without vibration, reducing noise even more. For this, it uses a design which is distinguished by an extremely weak electrostatic magnetic field.
A clean current from the source.
The Nativ Pulse shows a great quality of design, starting as soon as it enters. For this, it incorporates an AC filter,manufactured by Schurter, with high attenuation, thus virtually eliminating interference and EMI / RFI noise.
A chassis worked, an ergonomic display.
The high-quality 7000 Aluminum Pulse housing has a reflective design, even in its chassis. This anti-magnetic housing protects the components of the power supply from electromagnetic and mechanical interference, but also eliminates the negative effects of long-term thermal radiation. The power supply also features a dual tilted display (2 x 2.7 ") for displaying spectrometer information, such as voltage, current and power for inputs, in a readable manner.
www.audiophonics.fr/img/cms/products/12267/Nativ-Pulse-ultra-low-noise-linear-power-supply-homepage-5-GUI-high-res.jpg "alt =" Nativ-Pulse-ultra -low-noise-linear-power "/>
SPECIFICATIONS
Tension / CurrentDC + 12V 5A - DC +/- 15V (0.5A)
Designlinear
Total capacity50,000 μF
<controllers/ Td>25x linear regulators
Toroidal transformerNuvotem Talema
Power filterSchurter anti EMI / RFI
<compatibility/ Td>Designed to work with DAC Nativ Wave and Nativ Vita network player
chassisAluminum 7000 and wood
Infrared remote controlYes
InputIEC C14
ColorWalnut
ColorOther
Output voltage (V)12.0
Output current (A)0.5
Output current (A)5.0
Input voltage (V)230.0
Input voltage (V)120.0
Power SupplyLinear
