HiVi SWANS M8N Speaker Driver Woofer Aluminium Magnesium 80W 8 Ohm 86dB 29Hz - 2000Hz Ø20.3cm
Reference : 5771
74,90 €tax incl.
62,42 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
The "M" loudspeaker range from manufacturer HiVi is a synthesis of all the technological advances made in recent years in the field of electroacoustics.
It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely in the forefront.
Peripheral suspension in natural rubberloudspeaker to the loudspeaker, and participating in absorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Specifications:
  • Nominal Impedance:8Ω
  • Rated Power:80W
  • Maximum Power Output:160W
  • Sensitivity (2.83v / 1m): 88dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 35mm
  • Length Coil:17.5mm
  • Type of Support Coil:Kapton
  • Composition Coil:Aluminum Wires Copper Plated
  • Composition Magnetic Circuit: Ferrite
  • BL:9.6
  • Hey :6mm
  • XmaX:5.8mm
  • Cms:822
  • Qms:5.02
  • Qes:0.5
  • Qts:0.45
  • Mms:53.1g
  • Sd:0.0214m2
  • Vas:53.5L
  • Weight:2.54Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/5771/5771_m8n_1.jpg
https://www.audiophonics.fr/images2/5771/5771_m8n.jpg
https://www.audiophonics.fr/images2/5771/5771_m8n_2.jpg
https://www.audiophonics.fr/images2/5771/5771_m8n_4.jpg
https://www.audiophonics.fr/images2/5771/5771_m8n_5.jpg
https://www.audiophonics.fr/images2/5771/5771_m8n_6.jpg
Speaker Power (W RMS)80.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)203.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)29
Highest frequency (Hz)2000
