TOPPING PROFESSIONAL E4X4 PRE USB Audio Interface White
With the E4x4 PRE, Topping offers an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of performance for seamless recording and playback.
By buying this product you get 25 loyalty points
Reference : 19749
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 17-11-2026.
Topping E4x4 PRE USB Audio Interface 4 In 4 Out  24bit 192kHz White
Topping E4x4 PRE: 3/4 view
Topping E4x4 PRE : Key functions
Topping E4x4 PRE: Microphone preamplifier modules
Topping E4x4 PRE: Ultra-linear microphone preamplifier modules
The Topping E4x4 PRE is equipped with four ultra-linear microphone preamplifier modules developed by the brand, with an input noise of just -130.5dBu. Even at its maximum volume level, the E4x4 PRE can maintain a very low noise floor, ensuring that every detail of your recording is perfectly captured. This ultra-linear architecture ensures that the audio signal is transmitted with sufficient precision for a perfectly clear and transparent recording.
Topping E4x4 PRE : Phantom power supply
Equipped with 48V phantom power and a switch to activate or deactivate phantom power for each of the four inputs, the Topping E4x4 PRE is perfectly compatible with condenser and dynamic microphones.
Topping E4x4 PRE: Mic and instrument inputs
Topping E4x4 PRE: Low-noise voltage module
Topping's unique LNRD module provides a stable reference power level for the AD/DA converter chip, unleashing the chip's full potential for high-purity audio transmission.
Topping E4x4 PRE: Dynamic range and THD+N measurements
Topping E4x4 PRE: High-performance headphone amplifier
With a noise floor of just 0.9uVrms and an output impedance of 1Ω, the Topping E4x4 PRE's NFCA-LE headphone amplifier module enables the use of high-sensitivity headphones without distortion and noise.
The Topping E4x4 PRE offers two gain settings, high gain up to +17dBu and output power of 2x580mW at 32Ω. The combination of this high gain and significant output power means that the Topping E4x4 PRE can easily accompany professional headphones with high impedance, up to 600Ω.
The E4x4 PRE is also equipped with two headphone outputs, each of which can be independently monitored and adjusted via the Topping Professional Control Center software and dedicated volume knobs.
Topping E4x4 PRE: NFCA-LE amplifier and multiple gain levels
Topping E4x4 PRE: zero-latency monitoring
The zero-latency design allows audio effects to be monitored in real time during recording or mixing, for enhanced productivity.
Topping E4x4 PRe : Monitoring zéro latence
Topping E4x4 PRE: Analog volume control and wide dynamic range
The volume knobs on the line and headphone outputs use an analog potentiometer, offering excellent precision for easy control of sound level.
Topping E4x4 PRE : Independent mixers
Equipped with four 12-channel input mixers, the E4x4 PRE allows easy adjustment and control of audio effects. What's more, its 8 DAW channels and 6 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
Download Topping Professional Control Center
Topping E4x4 PRE: independent mixers
Topping E4x4 PRE : High resolution audio
The Topping E4x4 PRE adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. This supports high-resolution audio streams for recording and playback, up to PCM 24bit 192kHz.
What's more, all four inputs are evenly mixed, enabling greater compatibility with mobile devices.
Topping E4x4 PRE : Interface USB XMOS
Topping E4x4 PRE: Two USB-C ports
Topping E4x4 PRE: Dual USB-C ports
The Topping E4x4 PRE uses USB-C connectivity for data transmission and power supply. We recommend connecting the auxiliary power connector if the E4x4 PRE is used in conjunction with a desktop computer, or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
Topping E4x4 PRE: Aluminum chassis
The Topping E4x4 PRE's components are protected by a sturdy, durable aluminum-alloy chassis, sober and modern.
Topping E4x4 PRE: Connection diagram
Topping E4x4 PRE : Connection diagram
Topping E4x4 PRE: Dimensions
Topping E4x4 PRE: Dimension diagram
Topping E4x4 PRE: Package
Topping E4x4 PRE : Package
Topping Professional audio interface comparison
E1x2 OTGE2x2E4x4 Pre
OTG interfaceYesNoNo
POwer supplyUSB-CUSB-CUSB-C
Interface typeUSB 2.0USB 2.0USB 2.0
MonitoringYes (adjustable mix ratio)Yes (adjustable mix ratio)Yes (adjustable mix ratio)
Input level indicator1 set of LED2 set of LED4 set of LED
Output level indicator2 set of LED2 set of LED4 set of LED
Mic preamp modulesUltra-linearUltra-linearUltra-linear
Headphone ampNFCA-LENFCA-LENFCA-LE
Supported sampling ratesUSB-C : PCM up to 24bit 192kHz
OTG : PCM up to 24bit 48kHz
PCM up to 24bit 192kHzPCM up to 24bit 192kHz
Control softwareYesYesYes
Supported OSMac, Windows, iOS, AndroidMac, Windows, iOS, AndroidMac, Windows, iOS, Android
Power buttonYesYesYes
Weight415g530g830g
Mix channels434
DAW channels868
Loopback channels646
Product typeUSB audio interface
USB protocolUSB 2.0
Mic inputs4x XLR / Jack 6.35mm combo connectors
Instruments inputs2x XLR / Jack 6.35mm combo connectors
Line inputs4x XLR / Jack 6.35mm combo connectors
Line output4x Jack 6.35mm
Headphone output2x Jack 6.35mm
Direct zero-latence monitoringYes (with mix knob)
Input vumetersYes (4x8 LED indicators)
Output vumetersYes(4x8 LED indicators)
Headphone amp modulesNFCA-LE
Supported sampling ratesPCM up to 24bit 192kHz
Control softwareYes (Topping Professional Control)
DAW channels8x
Mic inputs measurements (@ 24bit 96kHz)
Input noise-130.5dBu @ A-wt, 150Ω
THD+N-110dB (0.0003%) @ A-wt
Dynamic range115dB @ A-wt
SNR115dB
Crosstalk-140dB @ 1kHz
Frequency response20Hz - 40kHz (±0.2dB)
Max input level8.6dBu
Input impedance1.5kΩ
Available gain58dB + 20dB (20db Digital gain)
Phantom power supply48V
XLR connector
Line inputs measurements (@ 24bit 96kHz)
THD+N-107dB (0.00045%) @ A-wt
SNR115dB
Frequency response20Hz - 40kHz (±0.1dB)
Max input level23.9dBu
Input impedance9kΩ
ConnectorsJack 6.35mm TRS
instruments inputs measurements (@ 24bit 96kHz)
THD+N-108dB (0.0004%) @ A-wt
SNR115dB
Frequency response20Hz - 40kHz (±0.3dB)
Max input level14.8dBu
Input impedance1MΩ
ConnectorsJack 6.35mm TS
Line outputs measurements (@ 24bit 96kHz)
THD+N-100dB (0.001%) @ A-wt
Dynamic range analogique127dB @ A-wt, -40dB atténuation
SNR115dB @ A-wt
Crosstalk-128dB @ 1kHz
Max output level14dBu
Bruit1.8uVrms @ A-wt
Impédance de sortie100Ω
ConnectorsJack 6.35mm TRS balanced
Headphone outputs measurements (@ 24bit 96kHz)
Dynamic range analogique132dB @ A-wt, -40dB attenuation
SNR115dB @ A-wt
Crosstalk-120dB @ 1kHz
Max output level0dBu @ Gain = L
17dBu @ Gain = H
Bruit1uVrms @ A-wt
Impédance de sortie1Ω
ConnectorsJack 6.35mm TRS stéréo
Headphone output power2x580W @ 32Ω, THD+N < 1%
2x380W @ 64Ω, THD+N < 1%
2x198W @ 150Ω, THD+N < 1%
2x105W @ 300Ω, THD+N < 1%
2x55W @ 600Ω, THD+N < 1%
Power supply5VDC 0.8A via USB-C
Dimensions29.2 x 12.9 x 5cm
Weight830g
ColorWhite
InputJack 6.35mm
InputXLR
OutputJack 6.35mm
Max sampling rate192kHz
ColorWhite
Interface chipXMOS XU308
TOPPING PROFESSIONAL E4X4 PRE Audio Interface USB 4 In 4 Out 24bit 192kHz White
With the E4x4 PRE, Topping offers an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a...
