Section (mm²)
0 mm - 6 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Dominique S.
Bon produit.
Ce sofstart fait ce qu'on en attend et correspond à la description. Cependant, dans mon cas, mis en route par un bouton...
Dominique S.
Bonne pointe.
Ces pointes massives seront parfaites sous des enceintes tout aussi massives, associées aux contrepointes portant la réf. 8634...
Kevin R.
Parfaites
Ces fiches sont de très bien conçues !
Hook-up Wires
Find here all our wiring wires, sold by the meter, to cut, allowing the internal wiring of your devices and DIY projects.
  • Mono conductor
    Mono conductor
    Here you will find all of our single conductor cabling wires, sold by the metre, for the internal wiring of your appliances and DIY projects.
  • Multi conductors
    Multi conductors
    Here you can find all our multi-conductor cabling wires, sold by the metre, for the internal wiring of your appliances and DIY projects.
