Cables LAPP KABEL Ölflex are recognized for their excellent heat resistance. This model can indeed withstand temperatures of -50 ° C to + 180 ° C.
Its silicone insulation keeps it much more flexible than traditional PVC cables for easy installation problems and establishment in environments where space is limited
This cable contains no halogens.
| Characteristics | |
| Type | stranded wire ÖLFLEX HEAT 180 |
| Number of cores | 2 |
| Nominal voltage | 300/500 V |
| Insulating | Silicone |
| Conductor Area CSA | 1.5 mm² |
| max | 150°C |
| min | -50°C |
| Tension test | 2000 V |
| Outside diameter | 7.6 mm |
| Weight / meter | 90 g |
| Diameter (mm) | 7.6 |
| Number of conductors | 2 |
| Insulation material | Silicon |
| Shielding | No |
| Section (mm²) | 1.5 |
| Conductors material (Cable) | N/A |
| Conductors Plating (Cable) | None |
| Ground / Shielding | No |
