Medium-high frequency motor, 150 W MAX, 8 Ω.
High-performance, high-performance, professional-grade, high-performance, professional-quality, professional speaker with 12 "and 10" woofer. Replacement SP-30PAX / VC is available as an option, the acoustic values are given for a combination with the MRH-200 horn.
Specifications Speakers | |
Impedance (Z) | 8 Ω |
Resonance frequency (fs) | 750 Hz |
Maximum bandwidth fx-18000 Hz | |
Crowds. cutoff (fmax.) (12dB / oct.) | 2000 Hz |
Maximum power | 150 WMAX |
Nominal power (P) | 60 WRMS |
Pressure sound. (1W / 1m) | 109 dB |
Angle dispersion (green / sun) | according to flag |
Coil diameter | 44.4 mm |
Magnet diameter | 110 mm |
cutting | according to flag |
Mounting depth | according to flag |
dimensions | Ø 115 mm x 53 mm |
Weight | 1.7 kg |
Speaker Power (W RMS) | 60.0 |
Speaker Type | Horn loudspeaker |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 25.0 |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | 100.0 |
Max Linear Excursion (Xmax) (mm) | N/A |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 18000 |
