7HZ SALNOTES ZERO In-Ear Monitors
The 7Hz Salnotes Zero in-ear monitors are particularly affordable, yet still high-performance models. They feature a dynamic 10mm metal composite driver and N52 magnet to reproduce your music with clarity and musicality.
4.0 / 5
Reference : 18615
21,90 €tax incl.
18,25 € tax excl.
7Hz Salnotes Zero In-Ear Monitors IEM Dynamic Ø10mm Jack 3.5mm
In-ear monitors 7Hz Salnotes Zero
The 7Hz Salnotes Zero in-ear monitors are particularly affordable, yet still high-performance models. They feature a dynamic 10mm metal composite driver and N52 magnet to reproduce your music with clarity and musicality. In terms of design, the 7Hz Salnotes Zero are clad in a plastic shell with a stainless steel faceplate. High-precision ergonomic measures have been taken to create earphones offering both good sound performance and excellent comfort.
The 7Hz Salnotes Zero are supplied with a detachable cable, connecting to the headphones via a 0.78mm 2-pin CIEM connector. The cable itself features OFC copper conductors for excellent conductivity.
Product typeIn-ear monitors
Drivers typeDynamic
Drivers diameterØ10mm
Shell materialsPlastic and stainless steel
Cable conductors materialOFC Copper
IEM connectorsCIEM 0.78mm 2 pins
Cable connectorJack 3.5mm
Impedance> 32Ω
SPL108dB/v @ 1kHz
Frequency response10Hz - 20kHz
THD< 1% / 1kHz
ColorSilver
Impedance (Ω)32
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)10
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
très bien et pas cher c'est possible
J'ai choisi cet IEM d'après la base de données des réponses en fréquences du site Squiglink. La courbe des 7HZ Salnotes Zero se superpose parfaitement à la cible du casque Grado SR325e. Un model de référence pour moi en matière de neutralité. Le résultat est conforme aux prévisions. Ni boumi dans le grave, ni agressif dans l'aigu. Parfaitement plat au milieu et confortable. Si c'est bien un son HiFi neutre que vous cherchez, ne vous laissez pas influencer par le prix incroyablement bas pour cette qualité. À voir dans le temps pour ce qui est de sa longévité.
This review has been posted for 7HZ SALNOTES ZERO In-Ear Monitors IEM Dynamic Ø10mm Jack 3.5mm
The 7Hz Salnotes Zero in-ear monitors are particularly affordable, yet still high-performance models. They feature a dynamic 10mm metal composite...
