DDHIFI E13P MEMORY In-Ear Monitors IEM
ddHiFi's E13P Memory are in-ear monitors developed in collaboration with Moondrop. They feature a newly designed 13mm planar magnetic driver, offering increased sensitivity while maintaining excellent harmonic distortion across the entire frequency range. In addition, these earphones come with a USB-C cable equipped with a CS43198 DAC capable of supporting signals up to 32bit 384kHz PCM and native DSD256.
Reference : 21123
169,00 €tax incl.
140,83 € tax excl.
Last items in stock !
Shipping date: 01-12-2026.
ddHiFi E13P Memory In-Ear Monitors IEM Planar Magnetic
DD HiFi E13P Memory : Front view
ddHiFi
's E13P Memory
ddHiFi E13P Memory: 13mm planar driver
For their E13P Memory earphones, DD HiFi has partnered with Moondrop to design a new type of 13mm planar magnetic driver. This driver offers 10 times the electroacoustic efficiency of a conventional planar driver and provides a wider dynamic range, even at low power. As a result, this new driver has a harmonic distortion rate of less than 0.05% across the entire frequency range, ensuring high-resolution, detailed sound reproduction.
DD HiFi E13P Memory : Speaker composition
DD HiFi E13P Memory : USB-C connector
ddHiFi E13P Memory : USB-C cable with integrated DAC
The E13P Memory comes with a USB-C cable featuring a CS43198 DAC chip capable of supporting signals up to 32bit 384kHz PCM and native DSD256. In addition, the included cable is shielded to ensure interference-free signal reproduction and features a microphone for easy phone calls.
ddHiFi E13P Memory: Retro-style carry bag
To ensure you can take them with you wherever you go, the E13P Memory headphones come with a synthetic leather carrying case designed to resemble a tape player. The case has two separate internal compartments to prevent the metal earphones from scratching each other.
DD HiFi E13P Memory : carrying case
Product typeIn-ear monitors (IEM)
DriverPlanar magnetic 13mm
Cable connectorUSB-C
Frequency response20Hz-20kHz
DAC chipCS43198
Native DSD up to DSD256
Cable conductorsOCC Copper
Microphone
ColorSilver
Package1x ddHiFi E13P Memory
1x Carrying case
3x Pairs of ear tips (S / M / L)
ColorSilver
Impedance (Ω)NC
WirelessNo
Cable terminationUSB-C
Headphone / Earphone connectorNC
Phone call featureYes
Noise reductionNo
DDHIFI E13P MEMORY In-Ear Monitors IEM Planar Magnetic
ddHiFi's E13P Memory are in-ear monitors developed in collaboration with Moondrop. They feature a newly designed 13mm planar magnetic driver,...
