EARACOUSTICS CIPHER In-Ear Monitors
EarAcoustics Cipher earphones combine a spiral acoustic architecture with a reinforced magnetic circuit and a 10mm ceramic dome dynamic transducer to deliver an extended frequency response with a smooth tone, designed for long listening sessions without ear fatigue.
Reference : 21393
23,91 €tax incl.
19,92 € tax excl.
Shipping date: 01-12-2026.
EarAcoustics Cipher In-Ear Monitors IEM Dynamic Ø10mm 22 Ohm 110dB 5Hz-30kHz
EarAcoustics Cipher : Front view
EarAcoustics
 Cipher earphones
EarAcoustics Cipher: A rigorous design
The Ciphers are built around an internal architecture called ‘Nebula Soundfield Design,’ which takes the form of a spiral waveguide that synchronises the various components of the acoustic signal. This geometry precisely controls the path of sound waves from the transducer to the ear canal, eliminating phase shifts between frequencies that would otherwise generate destructive interference. The soundstage thus gains depth and positional stability, with each instrument retaining its natural location without any perceptible time lag.
At the core of this system, a 10mm dynamic transducer combines a ceramic dome with a polyurethane suspension. The rigidity of the ceramic maintains the linearity of the high frequencies up to the limits of human audibility, while the polyurethane suspension allows for controlled excursions in the low frequencies without mechanical distortion. This combination preserves the integrity of the signal across the entire audible spectrum.
The dual-cavity magnetic circuit system multiplies the magnetic flux applied to the voice coil. This magnetic intensification accelerates the transducer's transient response, enabling accurate reproduction of instrumental attacks and micro-dynamic variations. Separate chambers prevent parasitic resonances that would compromise midrange definition, ensuring that every expressive nuance remains audible even in complex passages.
EarAcoustics Cipher : Internal composition
EarAcoustics Cipher : Waveguide
EarAcoustics Cipher : Extended frequency response
The advertised wide bandwidth of 5Hz to 30kHz is part of an approach aimed at preserving micro-details while maintaining a solid foundation in the sub-bass range. However, this extension is accompanied by deliberate tonal adjustment, where the 6–8kHz range is contained to avoid saturation on the sensitive harmonics of the human voice, ensuring prolonged listening without auditory fatigue. This approach is reflected in a softened timbre, linear enough for precision but calibrated for comfortable listening.
EarAcoustics Cipher: Silver-plated copper cable
The 1.5m non-detachable silver-plated copper cable optimises conductivity while limiting resistance, preserving the dynamic consistency generated by the magnetic circuit. The 3.5mm jack termination ensures comprehensive compatibility with portable players, allowing direct use without additional adapters.
EarAcoustics Cipher : termination
Product typeIn-Ear Monitors
Driver1x Dynamic driver Ø10mm
Frequency response5Hz-30kHz
Impedance22Ω
Sensitivity110dB
Cable terminationJack 3.5mm
Cable conductor materialSilver-plated copper
Cable length1.5m
ColorRed
Package1x EarAcoustics Cipher
1x Carrying bag
2x Pairs of ear tips
ColorRed
Impedance (Ω)22
Efficiency / Sensitivity (dB)110
WirelessNo
Headphone / Earphone connectorNC
Phone call featureNo
Noise reductionNo
EARACOUSTICS CIPHER In-Ear Monitors IEM Dynamic Ø10mm 22 Ohm 110dB 5Hz-30kHz
EarAcoustics Cipher earphones combine a spiral acoustic architecture with a reinforced magnetic circuit and a 10mm ceramic dome dynamic transducer...
