The Fosi Audio IM3 are open-design in-ear monitors, fitted with 10mm dynamic drivers with dual N52 magnets and an aluminum-magnesium alloy diaphragm. Their frequency response of 20Hz to 20kHz and open structure aim for detailed and airy reproduction, while preserving the character of the music.
Designed for listening with mobile or Hi-Fi sources, they combine a detachable cable with 0.78mm 2-pin connectors, a 3.5mm jack plug and a supplied USB-C DAC. Their lightweight 3D-printed resin shell provides a comfortable fit, while the DAC allows connection to devices equipped with a USB-C output.
The Fosi Audio IM3 are open-design in-ear monitors, fitted with 10mm dynamic drivers with dual N52 magnets and dual cavity. Their aluminum-magnesium alloy diaphragm and tuning aim to preserve the character and detail of the music, while the open design promotes a more airy listening experience, likely to reduce fatigue during long sessions. Their frequency response extends from 20Hz to 20kHz, with an impedance of 32Ω and a sensitivity of 107dB.
The 3D-printed resin front chamber uses a honeycomb structure that reduces weight by more than 30%, down to 5g per earpiece. The shape, optimized from ear canal scans, aims to stabilize the fit and provide passive isolation rated at over 20dB. Combined with a smooth surface designed to limit irritation, this geometry promotes comfortable everyday wear.
The IM3 are supplied with a 5N OFC copper cable, detachable thanks to 0.78 mm 2-pin CIEM connectors, and a gold-plated 3.5mm jack plug. A USB-C DAC is also included: it supports a sampling rate of 384kHz 32bit, while its analog-to-digital converter operates up to 48kHz 24bit. This connectivity allows them to be used with compatible analog sources or USB-C devices via the supplied DAC.
Technical specifications
| Specifications | |
| Product type | In-ear monitors |
| Frequency response | 20Hz-20kHz |
| Impedance | 32Ω |
| Sensitivity | 107dB |
| Drivers | 1x Dynamic Ø10mm |
| Cable termination | Jack 3.5mm |
| Earphone connectors | CIEM 0.78mm 2 pins |
| Cable conductor material | OFC copper |
| General | |
| Weight | 5g / earpiece |
| Color | Silver and black |
| Package | 1x Fosi Audio IM3 1x Jack 3.5mm to CIEM 0.78mm 2 pins cable 1x USB-C to Jack 3.5mm DAC 6x Pairs of ear tips |
| Color | Black |
| Color | Silver |
| Impedance (Ω) | 32 |
| Efficiency / Sensitivity (dB) | 107 |
| Wireless | No |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
