Kiwi Ears Cadenza are in-ear monitors featuring a large 10mm diameter dynamic driver with beryllium cone. This type of membrane is often considered to be the most powerful.
Kiwi Ears Cadenza IEMs feature a dynamic driver with a 10mm-diameter beryllium cone. This technology offers great clarity and resolution across the entire frequency range. The unique properties of beryllium - thinness, lightness and rigidity - enable the diaphragm to respond quickly to audio signals, ensuring that every detail of the sound is reproduced with great fidelity.
The shell of Kiwi Ears Cadenza earphones is carefully designed to optimize speaker performance. The shell is 3D printed to precise specifications, ensuring perfect speaker alignment and fit. This precision engineering contributes to the Cadenza's balanced sound signature, allowing the bass to retain the power and speed of response characteristic of beryllium, while avoiding a bulge in the midrange. The result is a rich, natural sound.
L'une des caractéristiques principales des IEM Kiwi Ears Cadenza est leur capacité à délivrer un son à la fois naturel, précis et sans fatigue auditive. La réponse des aigus des Cadenza a été soigneusement réglée pour refléter la norme de référence Harman, avec une courbe naturelle et une réponse sans agressivité. Malgré ce son naturel, les aigus dévoilent de nombreux micro-détails pour retranscrire toutes les nuances de la musique.
The Cadenzas have been acoustically tuned to deliver accurate, faithful sound. Bass is punchy and fast, and attenuates quickly enough not to dominate other frequencies. Mids are tuned to be rich but not excessive, allowing vocals and instruments to shine with exceptional clarity. Highs, meanwhile, are tuned to the Harman reference standard, for a natural, balanced sound that's detailed but not fatiguing to the ear. This meticulous tuning ensures that Kiwi Ears Cadenza deliver faithful, full sound, suitable for a wide range of musical genres.
Cadenza comes with a high-quality detachable cable, using braided copper conductors to ensure excellent conductivity. This cable terminates in a 3.5mm jack connector for maximum compatibility. It connects to the earphones using CIEM 0.78 mm 2-pin connectors, and can therefore be easily replaced.
Product type | In-ear monitors |
Drivers | Dynamic 10mm, beryllium diaphragm |
Sensitivity | 110dBSPL/mW |
Frequency response | 20Hz - 20kHz |
Impedance | 32Ω |
Shell material | Medical-grade resin |
Detachable cable | Yes |
In-ear monitors connector | CIEM 0.78mm 2 pins |
Cable end connector | Jack 3.5mm |
Channel separation | 88dB |
SNR | 95dB |
Supported sampling rates | Coaxial: up to 192kHz Bluetooth (LDAC): up to 96kHz |
Color | Blue |
Package | 1x Kiwi Ears Cadenza 1x Jack 3.5mm cable 6x Eartips pair |
Color | Red |
Color | Blue |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | 110 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
