KIWI EARS CADENZA II In-Ear Monitors Gray
The Kiwi Ears Cadenza II are a pair of dynamic in-ear monitors (IEMs) designed to deliver remarkable audiophile performance in an affordable format.
Reference : 22049
49,00 €tax incl.
40,83 € tax excl.
Shipping date: 19-11-2026.
Kiwi Ears Cadenza II Dynamic IEM In-Ear Monitors 18 Ohm 106dB 10Hz-29kHz Grey
The Kiwi Ears Cadenza II are a pair of dynamic in-ear monitors (IEMs) designed to deliver remarkable audiophile performance in an affordable format. As the successor to the renowned Cadenza, it features a 10mm dynamic driver equipped with a titanium-coated PET diaphragm, combined with Kiwi Ears' proprietary Kiwi Acoustic Resonance System 2.0 (KARS 2.0). This combination delivers deep and precise bass, rich mids, and detailed reproduction across the entire frequency spectrum. The Cadenza II features an impedance of 18Ω ±1Ω, a sensitivity of 106dB ±1dB at 1kHz, an extended frequency response from 10Hz to 29kHz, and a total harmonic distortion of less than 1% at 1kHz. Its design combines a polycarbonate composite shell with a CNC-machined aerospace-grade aluminum faceplate. It comes supplied with a 1.2-meter detachable OFC single-crystal copper cable featuring 0.78mm 2-pin connectors and a 3.5mm jack termination, ensuring broad compatibility with most portable audio players, USB DACs, and headphone amplifiers on the market.
Kiwi Ears Cadenza II: 10mm Dynamic Driver with Titanium Diaphragm
The Cadenza II features an all-new 10mm dynamic driver built around a titanium-coated PET diaphragm.
This structure combines the rigidity of titanium with the light weight of the polymer material to improve diaphragm responsiveness and reduce deformation. The result is more accurate sound reproduction, offering excellent detail retrieval and improved clarity of micro-details across the entire frequency range.
Kiwi Ears Cadenza II: KARS 2.0 Technology for Deep and Controlled Bass
The Kiwi Acoustic Resonance System 2.0 (KARS 2.0) is one of the Cadenza II's key innovations.
This technology uses a complex network of internal acoustic channels to precisely control the airflow generated by the driver. The system provides approximately 8dB of sub-bass enhancement with a precise cutoff at 200Hz, delivering deep and impactful bass while maintaining excellent cleanliness in the lower frequencies. This approach achieves a subwoofer-like effect without compromising midrange clarity.
Kiwi Ears Cadenza II: Detachable Single-Crystal Copper Cable
The Cadenza II comes with a high-quality detachable cable made of oxygen-free single-crystal copper (OFC).
Equipped with 0.78mm 2-pin connectors, it can be easily replaced or upgraded according to the user's preferences. This modular design also simplifies maintenance and extends the lifespan of the earphones. The cable measures 1.2 meters in length and terminates in a 3.5mm jack connector compatible with the majority of portable and desktop audio sources.
Technical Specifications
Product typeIn-ear monitors
DriverØ10mm Dynamic Driver with Titanium Diaphragm
DiaphragmTitanium-coated PET
Impedance18Ω (±1Ω)
Sensitivity106dB (±1dB) @ 1kHz
Frequency response10Hz–29kHz
Output powerRated: 5mW
Max: 10W
THD<1% (at 1kHz)
Channel balance<1.5dB (at 1kHz)
Detachable cable
Earphone connectorsCIEM 0.78mm
Termination3.5mm Jack
Cable length1.2m
ColorGrey
Weight4.45g/earpiece
Package contents1x Kiwi Ears Cadenza II Earphones
1x Detachable Cable
6x Pairs of IEM Ear Tips (S/M/L)
ColorGray
Impedance (Ω)18
Efficiency / Sensitivity (dB)106.0
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
KIWI EARS CADENZA II In-Ear Monitors IEM Dynamic 18 Ohm 106dB 10Hz-29kHz Gray
