By buying this product you get 27 loyalty points
The Kiwi Ears Orchestra Lite in-ear monitors have been designed on the same basis as the original Orchestra, but have been redesigned for greater performance and value. Orchestra Lite IEMs also feature eight Balanced Armature drivers and excellent tonal balance.
Kiwi Ears Orchestra Lite builds on the success of the original Orchestra model, offering the same eight-driver Balanced Armature configuration per earpiece, but with enhanced performance. Developed in close collaboration with loudspeaker manufacturers, this Lite version features custom Balanced Armature drivers for incomparable sonic richness and precision.
The Orchestra Lite are equipped with eight custom Balanced Armature drivers for optimum performance. These include two tweeters for precise highs, four drivers for clear midrange and two bass drivers for deep bass. These drivers work in harmony to produce a balanced, natural sound that faithfully reproduces the original audio source.
The Kiwi Ears Orchestra Lite have been meticulously tuned to achieve a natural, balanced tonal signature. Their three-way passive crossover system ensures complex layering and minimal harmonic distortion, with infrabass frequencies peaking at 8dB from 20Hz to 200Hz, neutral mids with only a 1dB variation from 200Hz to 800Hz, and highs perfectly aligned with human ear perception. This precision engineering enables every detail to be rendered with clarity and without aggression for extended listening sessions.
Each Orchestra Lite earphone undergoes two rigorous cycles of quality control, including frequency matching of the left and right channels, to ensure optimum performance. Handcrafted by Kiwi Ears technicians, these IEMs are designed to exacting standards, guaranteeing durability and reliability.
To maintain the Orchestra Lite's sound quality, Kiwi Ears has combined it with a four-conductor OFC 7N copper cable. This ensures excellent conductivity. The cable is detachable and connects to the earphones via a 0.78mm 2-pin CIEM connector. It can therefore be easily replaced if necessary. On the source side, a 3.5mm jack connector ensures compatibility with most devices.
Product type | In-ear monitors |
Drivers | 8x Balanced Armature (2x for trebles, 4x for midranges, 2x for bass) |
In-ear monitors connector | CIEM 0.78mm 2 pins |
Impedance | 16Ω |
Sensitivity | 112dB |
Cable end connector | Jack 3.5mm |
Cable conductors material | OFC copper |
Color | Blue |
Package | 1x Kiwi Ears Orchestra Lite 1x Jack 3.5mm cable 1x Storage case 9x Pairs of eartips |
Color | Blue |
Impedance (Ω) | 16 |
Efficiency / Sensitivity (dB) | 112.0 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
